A new car is coming... (WIP)
car gearbox
  • Please log in to reply
51 replies to this topic
#1 jorgeopesi
jorgeopesi
    Member: 11011
    Country: Spain
Posted 12 December 2012 - 06:30 AM
A few pics... It will be RC with a 7 speed and reverse manual gearbox like in my Huayra but this is 4WD. For the moment the hardest part was to build a front drive axle with servo motor and only 23 studs between wheels, most commonly they are 25 like in the rear axle but the proportions of the car are so. I don´t know yet what motors use or how many, I have room enough which is the most important thing and also works :laugh:  with a RC motor or a L motor worked fine.
Posted Image
Posted Image
Bu purist my friend.
#2 Lost_In_Noise
Lost_In_Noise
    Member: 25107
    Country: Norway
Posted 12 December 2012 - 07:40 AM
It looks like a good start. Now if I could only recall where I've seen those tires before..:)
My relationship is... Technical.
Sets
Reviews
#3 rm8
rm8
  • The BOSS of making Rock Crawlers feel blue
    Member: 19904
Posted 12 December 2012 - 08:34 AM
Very interesting. Does old suspension system from 8880 better than modern from 8070?
What is the difference? Tighter driving joints? Which suspension system is wider? 8070 or 8880?
Edited by rm8, 12 December 2012 - 08:34 AM.
#4 jorgeopesi
jorgeopesi
    Member: 11011
    Country: Spain
Posted 12 December 2012 - 10:21 AM
I don´t know which is better but the 8880 is wider, if I had been required even could have won 1/2 stud more for wheel. The 8880 lives inside us :laugh:  .
#5 AndyCW
AndyCW
    Member: 16308
    Country: USA(Ohio)
Posted 13 December 2012 - 01:34 AM
The control arm mounting locations on the spindle are 5 studs apart on the 8880 parts and only 3 studs apart on the 8070 parts.  This allows us to set up caster, camber, and camber curve more easily.  Because the distance from the pivot point to the steering linkage is longer on the 8880 hub, you need a rack that can travel further to achieve the same steering lock.  I really like the combination of these hubs, wheels, and tires.  I have tried some stuff with them in the past.  I am excited to see your progress.
Posted Image
My last project worth sharing http://www.eurobrick...138&hl=thrasher
I am frequently inspired by this TV show. http://www.powernati...xtreme-off-road
#6 jorgeopesi
jorgeopesi
    Member: 11011
    Country: Spain
Posted 13 December 2012 - 06:55 AM
I used caster, camber and more in my R8 but I discovered too much work for little gain, in next bigger MOCs like my unfinished Audi I will work only on suspension, steering and brakes. In this MOC I don´t use the liftarm differential receptacle :laugh:  front or behind and it is 1 stud wider than your axle.
Edited by jorgeopesi, 13 December 2012 - 09:05 PM.
#7 SNIPE
SNIPE
    Member: 16759
    Country: United Kingdom
Posted 13 December 2012 - 06:12 PM
Hi,
What is the maximum turning angle of the wheel and what is the max angle of the wishbones for the wheels (with no suspension), the front ball joint pivot I mean)
if its good enough I might try something like this as I cant find something that has good turning and wishbone stroke, I want it to turn sharply if needed even with or without 4 wheel steering)
#8 jorgeopesi
jorgeopesi
    Member: 11011
    Country: Spain
Posted 13 December 2012 - 09:04 PM
I will take some pics of the steering, it is the best way to see things :wink:  . I am thinking to remove the servo, really I think it won´t be necessary in a heavy car unable to run fast, for parking a small motor is enough :laugh:  .
Edited by jorgeopesi, 13 December 2012 - 09:10 PM.
#9 jorgeopesi
jorgeopesi
    Member: 11011
    Country: Spain
Posted 15 December 2012 - 03:45 PM
Steering angle pic and a video, it works but I have a lot of work, around 60 gears move when it works :cry_sad:  , I fear the Murphy´s law :laugh:  .
Posted Image
Posted Image
#10 hrontos
hrontos
    Member: 19500
    Country: Slovakia
Posted 15 December 2012 - 04:43 PM
Looks really good.
I like that you included traditional gearbox and gear shifting instead of sequential one.
#11 jorgeopesi
jorgeopesi
    Member: 11011
    Country: Spain
Posted 15 December 2012 - 04:55 PM
View Posthrontos, on 15 December 2012 - 04:43 PM, said:
Looks really good.
I like to build a sequential one, in fact I built one in a bigger car with 8448 wheels but with this scale there is no way.
#12 Meatman
Meatman
    Member: 4287
Posted 15 December 2012 - 05:30 PM
I love the idea behind the sequential gearboxes, but do they really work properly? I mean for driving vehicles of this scale and weight?
#13 jorgeopesi
jorgeopesi
    Member: 11011
    Country: Spain
Posted 15 December 2012 - 05:37 PM
For my experience is more for the building experience...
A lot of work...
For only this...
A RC motor, maybe with 4...
#14 jorgeopesi
jorgeopesi
    Member: 11011
    Country: Spain
Posted 28 December 2012 - 06:20 PM
It is being hard but it seems I am getting... or not...
Posted Image
Posted Image
#15 tibivi
tibivi
    Member: 25895
    Country: Belgium
Posted 28 December 2012 - 06:41 PM
looks like a porsche to me
I like it :grin:
Tibivi
My Brickshelf
My Flickr:
http://www.flickr.com/photos/tibivi/ <== check out my new MOCs here
Youtube channel: http://www.youtube.c...L?feature=watch
#16 Lipko
Lipko
    Member: 21244
    Country: Hungary
Posted 28 December 2012 - 06:43 PM
Your LADA is coming along nicely :laugh:
I mean Porsche
#17 jorgeopesi
jorgeopesi
    Member: 11011
    Country: Spain
Posted 28 December 2012 - 08:33 PM
It seems that the 6-cylinder engine is unmistakable :laugh:  .
#18 jorgeopesi
jorgeopesi
    Member: 11011
    Country: Spain
Posted 29 December 2012 - 01:08 PM
A good morning with progress better good morning :sweet:  .
Posted ImagePosted Image
#19 jorgeopesi
jorgeopesi
    Member: 11011
    Country: Spain
Posted 30 December 2012 - 11:36 AM
I need advice dudes, which ones better?.
#20 parda
parda
    Member: 14424
    Country: Spain
Posted 30 December 2012 - 11:52 AM
Better without rims
#21 Lipko
Lipko
    Member: 21244
    Country: Hungary
Posted 30 December 2012 - 12:00 PM
The second IMHO. Just try to be consistent. If the front is dominated by flex axles, then all the body should be.
#22 jorgeopesi
jorgeopesi
    Member: 11011
    Country: Spain
Posted 30 December 2012 - 12:06 PM
Parda you are a 8865 fanatic :laugh:  , everything is said. Lipko I use the flex axles for curves if there are more curves I will use them.
Edited by jorgeopesi, 30 December 2012 - 12:16 PM.
#23 denwilltec
denwilltec
    Member: 34968
Posted 30 December 2012 - 12:23 PM
Good build mate.. :classic:
#24 Balrog
Balrog
    Member: 11355
    Country: Germany
Posted 30 December 2012 - 12:31 PM
Looks good so far. Reminds me of the VW Beetle.
#25 jorgeopesi
jorgeopesi
    Member: 11011
    Country: Spain
Posted 30 December 2012 - 12:47 PM
Logical both cars have a common ancestor and it is an advantage I always change my MOC for a beetle :grin:  .
New year new ideas... a new hood with nice curves...
Posted ImagePosted ImagePosted Image
Edited by jorgeopesi, 02 January 2013 - 07:37 AM.
Also tagged with one or more of these keywords: car, gearbox
