I have the large Unimog wheels and all the necessary parts (gears, suspension, m motors, receivers beams, etc.). I just want to ask, are two m motors good enough to power (its going to be 4wd) something similiar to this size (length 32cm by width 26.5cm by height 20cm)? I am going to use another m motor to switch the dual speed gearbox. the gear ratios are probably going to be 1.4:1 and 11.6:1 (fast and slow). Additionally I will use another m motor to steer the truck.
Is there any way I can get the portal axle hubs to create a double wishbone suspension using beams and stuff? Also, I just need to know if the m motors are enough to power this thing (it won't be too big but it will have a PF 9v battery box on it)?
Will three m motors be enough to drive this thing over large obstacles (on first gear)? Please help.
Edited by sama, 04 November 2012 - 07:38 PM.
