What kind of suspension does an Ohskosh PLS truck use?
Help
  • Please log in to reply
3 replies to this topic
#1 Saberwing40k
Saberwing40k
  • Technic catch of the day
    Member: 22823
    Country: Luna
Posted 19 October 2012 - 12:45 AM
So, I'm kind of trying to make an Oshkosh PLS truck, and I've run into trouble with the suspension. I just can't figure out how it works. One of the brochures I've found seems to indicate that it uses walking beam axle (pendular) suspension, but in the same brochure it says the truck has a double cardon joint steering axle, which would indicate that it has independent suspension. I, however, think that the truck uses live axles, judging by the pictures I've seen. Can anybody clear this up?
Posted ImagePosted Image
Rumble is Red,Frenzy is Blue,
On Decepticon Cypertron,
Poem writes you!
My current project: ETF HTX-380, on Brickshelf, and Eurobricks.
#2 Bricktrain
Bricktrain
    Member: 7994
    Country: New Zealand
Posted 19 October 2012 - 07:19 AM
I dont know this truck, but some landrovers have a double cardan joint  on the front propshaft but a live front axle.
#3 cgarison
cgarison
    Member: 29668
    Country: U.S.A.
Posted 19 October 2012 - 07:21 AM
It would appear the Oshkosh PLS comes standard with a solid front axle, but an optional TAK-4 independent off-road front suspension is available.
http://www.autofield...s-a-truck-bgosh
#4 dhc6twinotter
dhc6twinotter
    Member: 10485
    Country: USA
Posted 19 October 2012 - 07:56 AM
The older PLS had solid axles, but the newer ones have the independent suspension that cgarison mentioned on the front two axles.  The rear two (or three) axles are still solid.  I get the impression that the independent front axles are standard, but they may optional....not sure on that.
I used to work on an Army base, and the PLS is an impressive machine.
Also tagged with one or more of these keywords: Help
