How can I tow these wheels in?
  • Please log in to reply
6 replies to this topic
#1 SNIPE
SNIPE
    Member: 16759
    Country: United Kingdom
Posted 11 October 2012 - 08:37 PM
Hi,
I have just added the steering arms and steering rack and there is two possible cones I can use, a 4l gear tooth strip mounted on a 6 hole liftarm thin with 4 studs (shown in red in the picture) with the 9L liftarms or a 10L technic gear rack with the 6l liftarms.
They have to have towball sockets so those are my choices. I have only tried with the 4l gear rack as im waiting for the 10L to arrive but even if both of these still have the wheels towed out , how can I tow them back in?
Note for each wheel hub/spindle there is 2 ball joints available so it can either be done all on one side or on both however I can't have it being too bulky otherwise it limites the steering. I also think this will solve the 'play' in the ball joints which makes the wheels wobble about, that could well make the toed in wheels even more toed in.
Here are the photographs of it.
Posted Image
Posted Image
Edited by SNIPE, 11 October 2012 - 08:37 PM.
#2 Bricktrain
Bricktrain
    Member: 7994
    Country: New Zealand
Posted 11 October 2012 - 10:50 PM
what is it like when the suspension is level, the different lenghts of the tie rod links than the suspension arms means the geometry changes with height. if you change to 6l links the geometry will be more constant, though without changing the suspension arms to 6l as well there will still be some change.
#3 SNIPE
SNIPE
    Member: 16759
Posted 11 October 2012 - 11:03 PM
it's not as bad but is still getting too much play. The suspention arms are horizontal as normal. an are  just over 6L
Edited by SNIPE, 11 October 2012 - 11:11 PM.
#4 Lipko
Lipko
    Member: 21244
    Country: Hungary
Posted 12 October 2012 - 05:05 AM
Use the other type of steering rack that fits to the 12t gear. That rack has more pin-holes and axle-holes, so you can put some extra pieces to get the desired rack width.
#5 MarkusOSX
MarkusOSX
    Member: 31068
    Country: Germany
Posted 12 October 2012 - 07:38 AM
Hi,
maybe like this ?
Posted Image
Greetz
Markus
Posted Image
#6 D3K
D3K
    Member: 30082
Posted 12 October 2012 - 07:51 AM
I would definately use the shorter linkages combined with the new type gear rack, odd length with both pin and axle holes. The axle holes are great for making it the perfect length in this kind of steering setup. I used more or less the exact same setup for my buggy-rod http://www.eurobrick...showtopic=74386 ,
Will try to get a better picture of the actual steering.
Sleep, eat, build, repeat
My BrickSafe Folders              Swingloader 2 instructions            6x6 Truck Instructions
#7 BachAddict
BachAddict
    Member: 18572
Posted 12 October 2012 - 07:54 AM
Watch nicjasno's car videos:
To make the wheels toe in, put the rack in front and move it away from the wheels to pull the links in.
