Thinking of getting into HF
  • Please log in to reply
10 replies to this topic
#1 Snark
Snark
    Member: 21023
Posted 16 September 2012 - 05:28 AM
So Bionicle and HF have always been things I was interested in, but never actually got into.
I'm thinking of taking he plunge into HF, but was just wondering, is there anything I should know before throwing money into this? In particular, I've heard that HF pieces have a propensity to break over time, any truth to that? Thanks.
#2 Zachattacx
Zachattacx
    Member: 29621
    Country: USA
Posted 16 September 2012 - 05:34 AM
Well Snark,HF pieces have never broken..well at least on me.Are you a brick fan?As in lego bricks
Edited by Zachattacx, 16 September 2012 - 05:35 AM.
#3 Mesonak
Mesonak
  • The tasty virtues
    Member: 6293
Posted 16 September 2012 - 05:55 AM
The initial wave of sets released in the summer of 2010 contained parts that were easily prone to breaking. With the parts redesign in early 2011, however, all further pieces, with the exception of the eye piece used for the Breakout waves as well as the two-toed clawed feet used in Toxic Reapa and Waspix (until recently - the piece was redesigned), are very resilient. I've only had one piece break, and it's an upper leg piece that I received from the Ordeal of Fire line. And I'd attribute that to being at the bottom of a large pile of limbs for several months and being crushed underneath their weight rather than inferior piece quality.
Other than that, there's really nothing you need to know. You get what you see with HF; ball and socket based build system that, while simple at first, is really quite complex below the surface. It's a pretty cool theme and such.
Edited by Mesonak, 16 September 2012 - 06:00 AM.
#4 Zachattacx
Zachattacx
    Member: 29621
    Country: USA
Posted 16 September 2012 - 05:59 AM
View PostMesonak, on 16 September 2012 - 05:55 AM, said:
The initial wave of sets released in the summer of 2010 contained parts that were easily prone to breaking. With the parts redesign in early 2011, however, all further pieces are very strong. I've only had one piece break, and it's an upper leg piece that I received from the Ordeal of Fire line. And I'd attribute that to being at the bottom of a large pile of limbs for several months and being crushed underneath their weight rather than inferior piece quality.
Could have not said it better.Simple as that.
#5 Snark
Snark
    Member: 21023
Posted 16 September 2012 - 06:06 AM
Thanks for the answers guys. Good to know the new pieces are sturdier. Just one last question then, do the pieces grow brittle over time or through extensive use? I will likely be constantly taking figures apart and rebuilding them into new designs, so will that possibly cause any damage?
#6 Mesonak
Mesonak
  • The tasty virtues
    Member: 6293
Posted 16 September 2012 - 06:15 AM
Not from my experience. With heavy usage, the pieces will loosen up, yeah, and obviously constant usage will cause them to wear down faster than if they were left alone. But from my experience, and create MoCs quite often with my sets, the pieces do not grow brittle. You should be fine. :classic:
#7 DraikNova
DraikNova
  • Exploded Brains.
    Member: 28078
    Country: Ninjago
Posted 16 September 2012 - 09:55 AM
Within all my Hero Factory MOCs, the only thing that broke was a technic connector, so you should be fine. They are very strong, something I think I have definitely confirmed by making a 1-foot long T-rex solely out of the bone pieces and the aforementioned technic connector.
                        A new year, a new Mask of (Ultimate) Power, a new Matoran marching band.
Posted Image
a                                 My MOCpages
a                                 Lavaria's Mini Magma Mecha
a                                  Macy's Dragon - Sir Chompsalot
#8 MakutaNocturn
MakutaNocturn
    Member: 15997
    Country: Poland
Posted 16 September 2012 - 10:29 AM
HF is cool for MOC. BTW, IMO people should try making their own... themes :P Nobody can end it, you create the story and characters etc. Pretty cool thing to do.
#9 Aanchir
Aanchir
  • Color Encyclopedia
    Member: 8841
    Country: United States
Posted 16 September 2012 - 01:04 PM
Post-2010 Hero Factory parts in general actually tend not to break. There are exceptions-- some sets will use older styles of joints, and you'll want to be slightly more careful than usual with those (examples include the head piece used in the 2010 and 2012 Hero sets-- any parts that use a joint resembling this one should be used with caution). But for the most part the "breaking joints" issue from BIONICLE has been eliminated.
Other tips:
  • This should go without saying, but when you're just starting out a collection it can be best to try to obtain sets with compatible colors.
  • The "new building system" everyone's raving about was introduced in the early 2011 sets along with the new style of Y-joint. Any sets before that will be a bit harder to build with since they will use more Technic-style or BIONICLE-style building techniques.
  • Bricklink and the online Pick-A-Brick site are your friends when it comes to getting extra parts for MOCs. This especially applies to parts within the new building system, since those started being added to Pick-A-Brick in early 2011 and even those which have been removed often have reasonable Bricklink prices as a result.
  • Get yourself acquainted with the selection of bone and shell pieces. For instance, there are currently four torso bone sizes (5x6, 7x9, 9x9, 9x11), which have very different applications. Some people get frustrated with the proportions of the parts they have, not realizing that other options are available in other sets.
  • The ABSOLUTE BEST way to become acquainted with the Hero Factory building system and the parts it includes is through LEGO Digital Designer, which has a nearly-comprehensive list of Hero Factory parts (some helmets and a few of this year's newest parts are missing, but in general it's got a great bank of parts). Goof around with it either before or after you get your first Hero Factory sets to experiment with your options. With that said, LDD is not always a good substitute for real-life building, especially when working with complex multidirectional hinges like Hero Factory ball joints. So if you want to really get complex in your building, you're going to want to get the physical parts you need in your collection.
#10 DraikNova
DraikNova
  • Exploded Brains.
    Member: 28078
    Country: Ninjago
Posted 16 September 2012 - 01:23 PM
Another piece of advice is to make a rough guess as to what colorscheme you want to use and to buy as many sets with those colors as possible.
Posted Image
a                                 My MOCpages
#11 sheedun17
sheedun17
    Member: 32534
Posted 13 October 2012 - 11:13 PM
Speaking of pieces breaking, i think that the mahri and on for bionicle were crapy pieces.
