question regarding connection between two parts in LDD
  • Please log in to reply
4 replies to this topic
#1 Marc Muller
Marc Muller
    Member: 29841
Posted 15 September 2012 - 10:20 AM
hello
i am trying to connect an angle plate 1x2 1x4 and a technic brick 1x2 (with 2 holes) so that the technic brick is connected via the 2 holes to the 1x2 plate on the angle plate. LDD does not accept this....
Posted Image
is there any way around to connect those?
many thanks
Marc
#2 monsinjor
monsinjor
    Member: 30140
    Country: Croatia
Posted 15 September 2012 - 10:35 AM
No, I also tried that.
It seems that into these holes (on techinc brick) can only be applied axles, connectors and simmilar pieces.
#3 Vincent Kessels
Vincent Kessels
  • Mr. Tomato Bread
    Member: 10753
    Country: Netherlands
Posted 15 September 2012 - 11:34 AM
Well technically this is considered an illegal connection by TLG, because using more than one hole makes the clutch power to high.
This would mean that two 1x1 technic bricks should work, but it doesn't.  :wacko:
The workaround is to put two 1x1 plates between the bracket and two 1x1 technic bricks. However that means putting an extra plate thickness between the bracket and the brick.
Oh, and Welcome to Eurobricks, Marc!
#4 JopieK
JopieK
  • Kneecap Buster
    Member: 1180
Yups otherwise it will become an illegal connection (like Vincent posted while I was typing ;)). Sometimes very annoying, but not much we can do about it I'm afraid.
Posted Image
-== Classic LEGO trains are the best ==-
Do you need replacement stickers for LEGO (reproductions and customs): ministickers.nl
What then about the LEGuanO?!
#5 Marc Muller
Marc Muller
    Member: 29841
Posted 15 September 2012 - 02:30 PM
Many thanks for your help
Marc
