Black Cat
33 replies to this topic
#1 Zblj
Zblj
    Member: 7054
    Country: Slovenia
Posted 11 August 2012 - 09:19 PM
After a bit of teasing arround I managed to build an 8 speed transmission. So after making the tranny, I had to think of a car to use it. In my mind the car was a bit inspired by Lambo's look and a bit by Ford GT. Everything else was more or less improvized.
So here's the first picture. I just dont have the heart to peel off the race truck stickers  :sceptic:
Posted Image
The rear opens up using two air springs to show off the massive V12 middle-to rear placed engine. Also the exhaust pipes are nicely visible.
Posted Image
I was limited with the number of black panels, so the doors may seem a bit skinny. Each door uses a spring to help it lift up and lower. It also keeps it in end position.
Posted Image
The crown of the car is the 7+R gearboy (A first that I know off) with next gear ratios:
1 1:3,472
2 1:2,778
3 1:2,083
4 1:1,667
5 1:1,25
6 1:1
7 1:0,75
R 1:2,25
These are possible thanks to 20 and 16 tooth gear combos.
Posted Image
The way the power is delivered from all the four wheels is also complex. More or less everything is placed assimetrically to gain as much room as possible. Notice where the central differential is placed. And the fact, that the rear wheels due to being larger than front have a slightly different gear ratio.
Posted Image
You may have noticed that the front diff is offset half a stud in front. This has two advantages. The steering rack is this way one the proper place. Also thanks to ackermann effect due to links, this allows the inner wheel to steer at a higher angle than usual, which translates to a higher steering angle.
Posted Image
Another view of the gearbox. Notice the angled chassis connectors. These are at such an angle to make room for gears and to better support the floor.
Posted Image
The rear of the car with its 4 exhausts and the spoiler:
Posted Image
Posted Image
Another new thing in this car is the suspension. The springs are not directly attached to the upper links, but via the 3L half beam. The lower arm is connected to that half beam with a yellow 5L half beam. What this does is, that when the suspension is pushed upwards, the yellow links pull down the 3L half beams, therebye additionally pushing the springs. There are two benefits. Being a sportscar this lowers the suspension travel and hardenes the springs. It also makes the spring move in a more linear fashion.
Posted Image
Another thing this car has is also an adjustable steering wheel, you can see that and more in the video:
Never say never!
MY YOUTUBE
Posted Image
WINNER OF 2010 TECHNIC CHALLENGE
TOP 100 OF 2013 TECHNIC CHALLENGE
OWNER OF THE LIMITED EDITION EXCLUSIVE 41999 MODEL
Posted Image
#2 jorgeopesi
jorgeopesi
    Member: 11011
    Country: Spain
Posted 11 August 2012 - 09:31 PM
Nice car, you give me an idea  :thumbup:
#3 DLuders
DLuders
  • Technic Technician
    Member: 7868
    Country: USA (WA State)
Posted 11 August 2012 - 09:32 PM
This is very nice!   :thumbup:   I can some design elements from the Ford GT40, and (on other topic) Phoxtane noticed its strong resemblance to the Lamborghini Gallardo:
Posted Image  Posted Image
#4 Zblj
Zblj
    Member: 7054
    Country: Slovenia
Posted 11 August 2012 - 09:37 PM
Thanks for thumbs up!
For those who cant see the original version, there will be a muted version available here:
Never say never!
MY YOUTUBE
Posted Image
Posted Image
#5 mahjqa
mahjqa
    Member: 108
Posted 11 August 2012 - 09:39 PM
Some very fine work, especially with the suspension and steering.
#6 timslegos
timslegos
    Member: 19027
    Country: United States
Posted 11 August 2012 - 09:41 PM
Another awesome MOC, nicely done.
tim
#7 TimH
TimH
    Member: 27781
    Country: USA (NC)
Posted 12 August 2012 - 01:36 AM
Very nice MOC!   :thumbup:
#8 timslegos
timslegos
    Member: 19027
Posted 12 August 2012 - 01:38 AM
Are you going to remove the green screen?
tim
#9 Saberwing40k
Saberwing40k
  • Technic catch of the day
    Member: 22823
    Country: Luna
Posted 12 August 2012 - 04:12 AM
Sorry, but I built a 7+R gearbox, and published it before you did. It was part of my
8070 Super Sports project.
Sadly, it did not work all that well, so yours is better.
And it comes in a great wrapper, too! :thumbup:
Posted Image
Rumble is Red,Frenzy is Blue,
On Decepticon Cypertron,
Poem writes you!
My current project: ETF HTX-380, on Brickshelf, and Eurobricks.
#10 Paul Boratko
Paul Boratko
    Member: 15227
Posted 12 August 2012 - 06:00 AM
I think he means with those specific gear ratios that he stated... His reverse gear is also on the opposite side of his transmission which is different than the one that you built, making this gearbox a little more unique... The key to getting 7 speeds(and reverse) to work well is stability in the structure that houses the axles and gears... If your structure is strong and rigid and your gears and axles stay true using liftarms rather than perpendicular connectors on axles, then everything should work smooth without binding up...
7+R gearboxes were done years ago, in fact there were gearboxes done with 14 speeds that I have seen many many moons ago and I am pretty certain that Zblj already knew that, so I think that he was referring to his own design here... :wink:
The problem with these larger speed transmissions is that it begins to alter the overall proportions of the car because they begin to take up too much room between the seats and make the car wider than it should be....
I think it is time for Lego to bring out some new sized clutch gears so we can start to build transmissions properly instead of making them harder than they need to be...
By the way Zblj, if you want to peel off the stickers, I'll be more than happy to hook you up with a brand new sticker sheet...  :wink:
Just P.M. me your address...
Edited by Paul Boratko, 12 August 2012 - 06:16 AM.
Posted Image
#11 rm8
rm8
    Member: 19904
    Country: Russia
Posted 12 August 2012 - 06:32 AM
idea  :thumbup:
Stickers :thumbdown:
#12 Andyrccar
Andyrccar
    Member: 27432
    Country: UK
Posted 12 August 2012 - 08:13 AM
View Postrm8, on 12 August 2012 - 06:32 AM, said:
idea  :thumbup:
I love it , more sticker would be better
#13 Zblj
Zblj
    Member: 7054
    Country: Slovenia
Posted 12 August 2012 - 08:42 AM
Well I guess thank to Paul you wont see any stickers for a long time  :tongue: About the 7+r gearbox. The first design had lots of friction because the low gears were powered from the top ones down, making a long chain of gears. So in order to make it more efficient the gears are powered from low ones with highest gear ratios and therefor friction to the top ones, which roll smoothest. Also thanks to 24 tooth gears I was able to pull off 12:20 gear ratio for odd gears and room for another 8 tooth gear for reverse gear.
Never say never!
MY YOUTUBE
Posted Image
Posted Image
#14 Zblj
Zblj
    Member: 7054
    Country: Slovenia
Posted 12 August 2012 - 09:12 AM
So here's a stickerless version:
Posted Image
Never say never!
MY YOUTUBE
Posted Image
Posted Image
#15 Jurgen Krooshoop
Jurgen Krooshoop
    Member: 9323
    Country: The Netherlands
Posted 12 August 2012 - 09:44 AM
Good lookin' MOC with good functions  :thumbup: . And it looks a lot better without the stickers. This is why I don't put stickers on my bricks in the first place.
Edited by Jurgen Krooshoop, 12 August 2012 - 09:48 AM.
Posted Image
Jurgen's Technic Corner      Brickshelf              MOC-Pages        Email
#16 captainmib
captainmib
    Member: 19532
Posted 12 August 2012 - 01:09 PM
I like the stickerless version better as well.
Nice car and that gearbox is huge!
How many gears did you use? Around 20?
#17 Zblj
Zblj
    Member: 7054
    Country: Slovenia
Posted 12 August 2012 - 01:37 PM
I just counted them:
2 x 8 tooth gears
10 x 12 tooth bewel gears
5 x 12 tooth gears
14 x 16 tooth gears
8 x 16 tooth clutch gears
8 x 20 tooth gears
3 x 24 tooth gears
2 x knob gears
1 x old sytle diff gear
2 x new style diff gears
So the total is 55 gears.
Never say never!
MY YOUTUBE
Posted Image
Posted Image
#18 DLuders
DLuders
    Member: 7868
Posted 12 August 2012 - 01:46 PM
@ Zblj:  Are you planning on making a Lego Digital Designer (LDD) .lxf file, or does meshing the 55 gears  *oh2*   in LDD take too much time?
#19 Zblj
Zblj
    Member: 7054
    Country: Slovenia
Posted 12 August 2012 - 01:49 PM
Supply and Demand, David. If enoughy people demand, than I may make them.
Never say never!
MY YOUTUBE
Posted Image
Posted Image
#20 captainmib
captainmib
    Member: 19532
Posted 12 August 2012 - 03:13 PM
2 x 8 tooth gears
5 x 12 tooth gears
14 x 16 tooth gears
8 x 20 tooth gears
3 x 24 tooth gears
2 x knob gears
Wow that's a lot!
Haha, Dluders, you know how to put some pressure on a builder. Meshing that amount in LDD must be very very frustrating  :devil:
#21 DLuders
DLuders
    Member: 7868
Posted 12 August 2012 - 03:34 PM
Yes, but Zblj is the BEST in the world in making difficult Lego Technic models in LDD.  If anybody can do it, he can!   :sweet:
#22 grohl
grohl
    Member: 11368
    Country: Czech Republic
Posted 13 August 2012 - 07:24 AM
Yes, the version without stickers does look a lot better. The headlights are awesome.
YouTube   Facebook BrickShelf  Flickr
I know the pieces fit.
#23 Povratnik
Povratnik
    Member: 11312
    Country: Slovenia
Posted 13 August 2012 - 08:36 AM
Without stickers is definitely better. Well done.  Can you take some more pictures from the different angles, so we can see this beauty better.
Technic once, Technic forever !
Posted Image
#24 mo_
mo_
    Member: 26849
    Country: Australia
Posted 13 August 2012 - 08:59 AM
This is just amazing! You are a talented builder.
I enjoy seeing these types of creations, keep up the good work  :thumbup:
Support the Vampire GT on Lego Cuusoo http://lego.cuusoo.c...deas/view/13666
#25 Zblj
Zblj
    Member: 7054
    Country: Slovenia
Posted 13 August 2012 - 02:27 PM
Thanks! Praise means a lot to me  :classic:
Never say never!
MY YOUTUBE
Posted Image
Posted Image
Reply to this topic
