Crazydance, on 09 July 2012 - 09:43 AM, said:
... But indeed if one of the motors is slightly slower or reacts slower than the other it may cause a problem.
You can correct this with a differential which can actually catch the difference between the two motors.
Another question. WHY do you need this construction specifically? You could use a L or XL motor with some gearin instead.
I don't know the exact mechanics of it, but my intuition is that issues with slight differences in speed would only occur if it's running unloaded. As soon as there's a load applied, it would sort of force them to work at the same speed. Kind of like how having multiple engines on a single train works. If A goes a little bit faster, it takes the load off of B, which is then unloaded and goes faster, catching up with A. Negative feedback ftw.
As to why, I've reached my budget for the forseeable future, and plan to build what I can with what I've got before I go buying anything extra, including XL motors.
Currently I've got:
- 8110 Unimog
- 8109 flatbed (+ 6 extra wheels)
- 8043 excavator (on it's way)
- My kids' moderately sized collection of System lego, including a 7685 dozer
This gives over 4000 technic parts to play around with, including 2 IR remotes, 6x PF M motors, pneumatics, 4 linear actuators, 3 diffs, many uni joints, a bunch of tank track, 4 big wheels and 12 small ones, etc, and I've already got quite a few ideas:
- A pair of simple RC cars
- A pair of simple RC tanks
- A big RC tank with suspension of some sort and controllable turret
- A big 4wd RC car, of similar design to the 9398 crawler in terms of motor placement and suspension, using the unimog wheels and possibly paired motors for drive (4xM total for drive!)
- Some kind of halftrack maybe.
When I get through all of that, I might think about buying some new parts :)
