First you'll need these pieces http://www.bricklink...tem.asp?P=30176
These pieces are made of a softer than normal plastic that makes it ideal for carving.
You will also need...
Exacto Knife with new blade
Cutting Surface (I used a padded envelope from bricklink)
Small Pot
Metal Strainer
Cooking Thermometer
Water
Bulldog Clip
Minifig
Painter's masking tape
Band aids
Antibiotic ointment
First thing is to cut the top of the piece so it is level with the upper leaf.
Then the bottom so it is level with the Bottom Leaf.
Now carve a U Shape out of the bottom of the piece away from the leaves. After this step you will probably need to use the ointment and band aids. Next time I do this, I will use the bandaid first to protect my thumb before cutting it. Carving slowly will reduce the chance of injury.
Now, testfit the vambraces by removing the minifig hand and slipping the vambrace over the arm and putting the hand back in. You may need to carve more, especially if you want the arms to move. Ok, Now take the vambraces off again. Put the water in the pot, and the strainer and thermometer in the top of the pot. There should be enough water so the piece can be submerged in the strainer.
Like this, but don't put the legos in yet. Boil the water and wait for it to cool down about 20 degrees. Now put the vambrace in the bulldog clip and submerge the vambrace. (The Magnet Minifig is there for another reason) Wait about 5 minutes and take it out and immediatelly bend the leaves back and hold them. I could not get a picture of this step due to the use of both hands and the speed that I Needed to work.
Now Tape the leaves together with the piece of the Painter's Tape.
Wait about 24 hours and unwrap them. They should look like this.
Now they can be placed back on your minifig of choice. I bet they would look good with the pumpkin head or on a Poison Ivy fig.
Plant people Rule!
