I just got the three new technic sets today, but I won't have time to build them until the weekend. However, as a sneak preview, I opened up the Snowmobile just to see the treads, since I have a love of treaded vehicles.
Here's my impression: Cool!
They're big; I didn't expect them to be so big, but I actually like that. They're exactly twice as wide and twice as long as the old technic treads; making them 5x2 per tread. They're a lot sturdier than the old treads, which was my biggest complaint about the old ones; there's no way these things are going to decouple from each other (well okay, I'm sure someone with a fast enough motor can figure out a way ;-)). Another plus is that they have a deep pattern on them, as opposed to the old "5 small holes" on the old treads, so this means that they'll grip into surfaces much better than the old treads. They seem to have a lot more friction due to this, and will work better (but still not nearly as good as a rubber wheel) on smoothe surfaces.
However, there is a downside; they had to make a new notched wheel piece to use with them, since the standard teeth of a gear are too close together to fit into the treads now. So the bad part is that you can't use gears with these, and you're required to stick to using the new cog piece. However the good news is that the model comes with four of these cogs, and they're the same size as a 24T gear.
So, my initial verdict: I like em, and I think I'm going to buy another snowmobile to get more.
I think I'll post my reactions to the snowmobile itself when I build it sometime later this week.
New Treads from 8272 Snowmobile
Started by
Mithrandir
, Nov 16 2006 03:24 AM
8 replies to this topic
#4
Posted 18 November 2006 - 06:11 AM
Here's a sneak preview:
http://www.brickshel...ew_lego_001.jpg
Gallery isn't moderated, but images range from 001 through 033. :)
#7
Posted 18 November 2006 - 10:11 PM
*y* great pics of the new treads Thanks.
What kit does the new axle appear in?
#8
Posted 19 November 2006 - 05:24 PM
New axle is in the $20.00 set, 8271 Wheel Loader. There's two of them.
It's 8 studs long and has a stop at the end, which is incredibly useful for getting it to fit into tight places, as the model does quite nicely.
I might decide to get another one of those sets too.
Reply to this topic
