MOD: 8466 Off-Roader new springs.
12 replies to this topic
#1 Lost_In_Noise
Lost_In_Noise
    Member: 25107
    Country: Norway
Posted 30 April 2012 - 06:27 PM
My 8466 currently looks like this, and the suspension is virtually non-functional. I bought it second-hand, but I've seen others mention this problem. It can either be that the springs are underdimensioned for the car, or that they have weared over time. To test this, I've decided to buy some new springs to tend to the problem.
With these springs:
Posted Image
The set originally contains 4 x "Technic, Shock Absorber 9.5L, Complete Assembly (Hard Spring)" (part no 2909c02), but I wanted to change it to four of these from the Unimog:
"Technic, Shock Absorber 9.5L, Complete Assembly (Extra Hard Spring)"
Posted Image
I've just ordered them yesterday, and will let you know as soon as they arrive with pics of the car.
Here is some pics of the model per today:
The main issue:
Posted Image
Normal state of display:
Posted Image
Front springs compressed, without any pressure applied:
Posted Image
Front spring position (neutral)
Posted Image
After a small bump:
Posted Image
Rear spring position:
Posted Image
After some pressure added, they return to this state:
Posted Image
The chassis is lowered approximately three studs, and doesn't come back up. I'm hoping the new springs will fix this issue.
My relationship is... Technical.
Sets
Reviews
#2 Rikus
Rikus
    Member: 26891
    Country: Italy
Posted 01 May 2012 - 12:09 AM
I own this model, too, bought used, but even changing the Shock absorbers with new ones (same type), the problem still persist, especially when playing with the model...
To better the recoil of the front suspension, without having to change the springs (or the whole shock absorbers), I exchanged the two 1x7 liftarms where under the engine with two 1x9 liftarms, attaching the shock absorbers at the tips.
Doing so, the suspension works much better, increasing efficiency by slightly reducing the tire excursion.
Tomorrow I'll take some pictures of it.
Edited by Rikus, 01 May 2012 - 12:11 AM.
#3 Lost_In_Noise
Lost_In_Noise
    Member: 25107
    Country: Norway
Posted 01 May 2012 - 10:23 AM
Did you change it with unimog springs? They are stiffer according to the lego website. If it doesn't work with new springs, I'll try fitting two springs to each wheel like the 8880 has. That 20-year old car still has working springs.
Sets
Reviews
#4 Erik Leppen
Erik Leppen
    Member: 7347
    Country: Netherlands
Posted 01 May 2012 - 12:57 PM
I suspect the problem is not the springs, but the way they're mounted. I mean, 8448 has four of the smaller springs, which are much lighter, and 8448 has more parts so if you count the suspended mass only (so don't count the wheels) I think 8448 might even be heavier than 8466. Yet 8448 seems to hold up pretty well. lack of suspension stiffness is probably not the problem, so simply adding more of it won't do. Well, yes, it will do, but it doesn't suddenly make the suspension smooth.
By the way, I think the core of the problem is the design fault in the springs, namely that the connection point is not in line with the spring, but offset by a stud. This produces frictional forces. You could solve this by using the longitudinal axle hole instead of the one the set uses.
8880 simply suffers from way too much suspension stiffness by the way. 8448 did this way better.
#5 Lost_In_Noise
Lost_In_Noise
    Member: 25107
    Country: Norway
Posted 01 May 2012 - 02:39 PM
The 8110 Unimog has also, as far as I can recall, offset front suspension. I have never had any problems with that returning to normal position even after putting a lot of weight on it.
Ricco @ Technicbricks wrote:
Quote
"We got a couple of questions on the geometry of the front suspension of the new LEGO Technic U400 Unimog. Some of you is wondering why the front suspension is offset by half a module.
There is a geometrical reason for this, the front axle is stabilized by a Panhard rod, the panhard rod is there to prevent the entire front axle from moving from side to side. The shock absorbers would simply be too flexible to support the front axle on their own.
When the suspension is fully compressed, the front axle needs to be centered right underneath the vehicle in order to prevent the wheels from hitting the chassis and wheels arches, when turning.
That means when the suspension is fully extended the panhard rod will make a “circular” moment that pushes the front axle slightly to the right of the vehicle.
In the real world, these geometries are balanced out by fine tuning the length the panhard rod.
So if your front axle is offset by half a module, you have built your new LEGO Technic U400 Unimog the right way.
Edited by Lost_In_Noise, 01 May 2012 - 02:40 PM.
Sets
Reviews
#6 Choops
Choops
    Member: 12835
Posted 01 May 2012 - 02:51 PM
You may want to add the lower bracing to the suspension also. It helps reduce the flex in the suspension and therefor the shocks dont need to work as hard.
Here is a link to some good photos
http://www.lxtechnic...xa.com/8466.php
Steve
#7 Lost_In_Noise
Lost_In_Noise
    Member: 25107
    Country: Norway
Posted 01 May 2012 - 09:10 PM
I made some adjustments thanks to the comments made here. The results were much better, but hopefully I won't have to use these mods when the new springs arrive.
Rear Before compression:
Posted Image
Rear After compression:
Posted Image
Front before compression:
Posted Image
Front after compression:
Posted Image
The red beams are placeholders for L3 axles, to better indicate their position.
Posted Image
Posted Image
Side view, thin liftarms keeps the axles in place.
Posted Image
The rear suspension has a different setup, due to my parts availible.
Posted Image
Posted Image
Edited by Lost_In_Noise, 01 May 2012 - 09:40 PM.
Sets
Reviews
#8 Lost_In_Noise
Lost_In_Noise
    Member: 25107
    Country: Norway
Posted 09 May 2012 - 04:20 PM
Springs finally arrived. I've been setting it up tonight, and took some shots here:
Posted Image
Posted Image
Posted Image
Whole car without wheels:
Posted Image
Posted Image
Posted Image
standby front:
Posted Image
standby rear:
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
The front is actually in line with the rear after the new springs have been applied. See comparison in pre-mod shots.
Front before/after compression:
Posted Image
Posted Image
Rear before/after compression:
Posted Image
Posted Image
Up-close front:
Posted Image
and rear:
Posted Image
Everything works like expected, and I can recommend anyone who has the spring problem with the originals to try this out.
Sets
Reviews
#9 S.I
S.I
    Member: 12791
Posted 09 May 2012 - 07:29 PM
I'll have to try it, I noticed both my bought as used had worn out springs.
Have you noticed any issues with the tracking when the off roader is being pushed forward?
#10 Lost_In_Noise
Lost_In_Noise
    Member: 25107
    Country: Norway
Posted 05 June 2012 - 05:34 PM
None whatsoever. It works as you would expect.
Sets
Reviews
#11 LegoJeeper
LegoJeeper
    Member: 29040
Posted 06 June 2012 - 08:59 PM
thanks,  firmer springs are what Lego needs, to allow heavier builds or larger vehicles
Please support my kids Lego Jeep Wrangler www.lego.cuusoo.com/ideas/view/17748
#12 FR Rayward
FR Rayward
    Member: 16171
    Country: Australia
Posted 09 June 2012 - 09:46 AM
Well, I built 8466 and had the same problem. I modded my truck to fit yellow pneumatic shocks. I mounted 4
control boxes in the rear tray, and piped each shock to one. Worked awesome! Pump it up hard and you can
hardly push the truck down, or drop them right down for city driving, like a Range rover. The benefit of
this as well is having control over the four corners, so you can prop it up on a rock, and squash two, and
extend two, articulation looks great on the model.
Try it!
#13 TechnicFreak
TechnicFreak
    Member: 13640
    Country: USA (Michigan)
Posted 11 June 2012 - 05:32 AM
Wasn't this topic on the forum a month or two ago, same issue, with the springs?  I recall reading at as I bought a new, sealed 8466 recently.
Reply to this topic
