Electric traffic lights for the railway
  • Please log in to reply
7 replies to this topic
#1 AlexC
AlexC
    Member: 27359
Posted 23 April 2012 - 02:39 AM
Guys,
I am trying to build an electric traffic light for my railway. For that purpose I will use two Electric, Light Brick 1 x 2 with Single Side Light (6035)and one Trans-Green Brick 1 x 2 without Bottom Tube (3065)and one Trans-Red Brick 1 x 2 without Bottom Tube (3065).
Does anyone built anything similar? If yes, could you please provide me with some building instructions or advises? Particularly I wonder how to switch lights if want to have only one battery box connected to both lights? I assume they should be connected through a sort of switch. Does anyone aware of that switch p/n?
Alternatively, if you could recommend any other ways to construct a traffic light I also will appreciate it.
Best regards,
Alex
#2 DLuders
DLuders
  • Technic Technician
    Member: 7868
    Country: USA (WA State)
Posted 23 April 2012 - 02:49 AM
@ AlexC:  Welcome to Eurobricks!   :classic:   Have you seen this LEGO 7867 12v Train Light Post Set Parts instructions page?  Is this the type of light you want?
Posted Image
#3 dhc6twinotter
dhc6twinotter
    Member: 10485
    Country: USA
Posted 23 April 2012 - 03:00 AM
Alex,
Since you are using old 9V stuff, I would suggest using the old polarity switch with old 9V wires:
Posted Image
You could also use the newer PF polarity switch, but you would need some PF converter cables:
Posted Image
You would have to use 1 switch per light.
If you wanted to get all fancy, you could buy a cheap RCX off bricklink to control your lights.   You might even be able to program it in with other track functions.   Some of the RCX's have a power plug so you don't have to use batteries.
Edited by dhc6twinotter, 23 April 2012 - 03:06 AM.
#4 DLuders
DLuders
    Member: 7868
Posted 23 April 2012 - 03:15 AM
@ AlexC:  Are you wanting to build something like Bill Ward's Four-Track Signal Gantry, except with LED lights in the signal faces?
Posted Image
#5 AlexC
AlexC
    Member: 27359
Posted 23 April 2012 - 05:45 AM
View PostDLuders, on 23 April 2012 - 03:15 AM, said:
@ AlexC:  Are you wanting to build something like Bill Ward's Four-Track Signal Gantry[/url], except with LED lights in the signal faces?
DLuders, thank you for your help. Four-Track Signal Gantry is probably too fance for me, but the idea is similar.
Also thanks for the Train light posts, at least i will use the set to build something similar.
View Postdhc6twinotter, on 23 April 2012 - 03:00 AM, said:
Alex,
dhc6twinotter, actually I want something with RCX to avoid alot of polarity switches.
Do you have any particular examples with RXC?
#6 JopieK
JopieK
  • Kneecap Buster
    Member: 1180
    Country: Netherlands
Posted 23 April 2012 - 01:23 PM
It will not be very efficient to use an RCX and (just) LEGO...
I use both RCX and NXT in education so I know quite something about them. You might of course try to do some electronics tricks with it, but a better solution is using e.g. the Arduino. Did you also want to make a block system for controlling the trains?!
New Member? Read This | Questions? Need Help?Ask Here
Site Guidelines | Eurobricks FAQ | Visual User Guide
Posted Image
-== Classic LEGO trains are the best ==-
Do you need replacement stickers for LEGO (reproductions and customs): ministickers.nl
What then about the LEGuanO?!
#7 dhc6twinotter
dhc6twinotter
    Member: 10485
    Country: USA
Posted 23 April 2012 - 08:30 PM
Sorry, I don't have any pictures or examples of electric traffic lights.   There is a LUG that travels around to some of the shows in the States, and they have a large train layout with RCX controlled bridges and train crossings.  The train crossings use the old 9V flashing lights and a micro motor to open/close the gate.
I think the train layout will be at BrickMagic in a month.  If you like, I can try to get more info on their layout when I see it.
Edited by dhc6twinotter, 23 April 2012 - 08:31 PM.
#8 AlexC
AlexC
    Member: 27359
Posted 24 April 2012 - 04:44 AM
Hi JopieK,
I think using something like Arduino is too much for me. May be you could give me some advises about RCX and NXT? I am not planning (so far) to make a block system for controlling trains as my trains are RC.
dhc6twinotter, I will appreciate if you could make some photos of it.
