My brick order has arrived much sooner than anticipated. I immediately started further assembly on the structure. It is currently at 130 studs long and 8 high and completes a full circle.
Thank you for your contributions,
Lego Otaku,
SNIPE,
davee123,
Xyver, and
Legoman.
@Lego Otaku, I did some pricing on 1x1 round bricks and hit a wall when it came to green. Of the estimated 150+ needed, pricing starts at $0.05/pc from single sellers with over 100, in US. If I do go that route, it won't be until May, that I can start orders
SNIPE, Those slope pieces would be great if the smooth ramp was convex rather than concave. I'm not familiar with them to determine how I would attach the green and red stripe. However, I do like the degree of their curvature
davee123 and
Xyver, Thank you for the useful info and pics regarding full 1x2 circles. 12-15 circumference is very tight for these bricks. There is no doubt in my mind I would not be able to do that at all, let alone without glue. My first pic above was at 50 studs and barely 1/4 turn. That said I am not sure I will be ruling glue out anyways, as this will be a permanent structure. I had just finished my cylinder base before checking this. Looking at the multicolor example, it looks identical. Even at 130L , it is under moderate stress. If it doesn't have an even stud height all the way around, it buckles due to uneven tension
Legoman, Thank you for sharing your experience on the matter. This model will just be what it is, a permanent structure. I am not too worried about stress and warping and don't plan to reuse these pieces. At most I would consider the whites, but as most are a little discolored, I see no further use. AS for the money, you are absolutely correct, they are cheap. I think I've spent just over $50 and have only received 1/3 of amount ordered. I'll keep you in mind regarding the white ones. As this project is an
OCTAN related build, I can't use yellow or blue.
I am trying to keep the stress, at most, moderate. At 130L I'm on the limit. I don't think I can get much shorter, especially with a projected height of 24. I my even have to make it a bit longer to make it easier to connect once I have it built up. And no worries on light. None of my Lego has seen light in 15 years... I'm very adamant about that
Here are pictures of the structure in it's current standing. As you can see it is quite a large scale:
Length 130 Studs
Projected Height 24 Studs
Full Circle @ 130L
Many thanks to all the help and ideas presented so far
