What's the angle?
  • Please log in to reply
17 replies to this topic
#1 pauldk
pauldk
    Member: 16051
Posted 21 March 2012 - 11:30 AM
Hi fellow brickers.
Is there a math genius who can solve my problem? I'm trying to figure out what the exact angles of the hinges are, on a model I'm making.
https://skydrive.liv...AIkFOmEefzZn29w
On the link above, you can see what I'm talking about. It's the hinges 1-7 I'm trying to figure out. The arch I'm making has to fit so I can put a two-dot brick in between (8) the orange end of the arch and the green brick at the end, if you know what I mean.
So anyone, please help me out.
Kind regards
Paul in Denmark.
Edited by pauldk, 21 March 2012 - 11:44 AM.
Best regards
Paul, Denmark.
The home of Lego.
#2 Bojan Pavsic
Bojan Pavsic
    Member: 9690
    Country: Slovenia
Posted 21 March 2012 - 11:31 AM
Image is not visible.
There's always a way to include Technic in any Lego creations.
#3 pauldk
pauldk
    Member: 16051
Posted 21 March 2012 - 11:45 AM
I had to make a link instead.
- Paul
Best regards
Paul, Denmark.
The home of Lego.
#4 Bojan Pavsic
Bojan Pavsic
    Member: 9690
    Country: Slovenia
Posted 21 March 2012 - 11:56 AM
What curve would you like the "line" to follow? Should the goal be that angles 2-7 would be as close to eachother as possible? Because this doesn't have a unique result...
#5 pauldk
pauldk
    Member: 16051
Posted 21 March 2012 - 12:24 PM
Well the curve has to be on the left side of the red line. Well it doesn't matter if angle 2-7 is as close to each other numerically , it just have to form a be a proper "round" curve, without too much of a gab where the hinges is.
- Paul
Best regards
Paul, Denmark.
The home of Lego.
#6 Bojan Pavsic
Bojan Pavsic
    Member: 9690
    Country: Slovenia
Posted 21 March 2012 - 01:39 PM
a = 9,00 / 10,00 / 10,80 / 10,10 / 9,70 / 10,60 / 60,20 / x = 48,0001 / y = 32,0003 / diff = 0,00000011 / 0,00040506
a = 9,00 / 10,00 / 10,90 / 9,60 / 10,90 / 9,30 / 59,70 / x = 48,0002 / y = 32,0002 / diff = 0,00000010 / 0,00044028
a = 9,00 / 10,00 / 10,90 / 9,70 / 10,40 / 10,00 / 60,00 / x = 48,0001 / y = 31,9998 / diff = 0,00000003 / 0,00022862
a = 9,00 / 10,00 / 10,90 / 9,80 / 10,00 / 10,50 / 60,20 / x = 48,0004 / y = 31,9999 / diff = 0,00000019 / 0,00048942
a = 9,00 / 10,10 / 10,40 / 10,60 / 9,70 / 10,20 / 60,00 / x = 47,9997 / y = 32,0002 / diff = 0,00000011 / 0,00046409
a = 9,00 / 10,10 / 10,40 / 10,70 / 9,30 / 10,70 / 60,20 / x = 47,9999 / y = 32,0001 / diff = 0,00000002 / 0,00020103
a = 9,00 / 10,10 / 10,50 / 10,30 / 10,00 / 10,10 / 60,00 / x = 48,0002 / y = 31,9999 / diff = 0,00000006 / 0,00032837
a = 9,00 / 10,20 / 10,10 / 10,90 / 9,60 / 10,20 / 60,00 / x = 47,9999 / y = 31,9996 / diff = 0,00000015 / 0,00047076
a = 9,10 / 9,80 / 10,70 / 10,40 / 10,20 / 9,50 / 59,70 / x = 48,0002 / y = 32,0003 / diff = 0,00000012 / 0,00046690
a = 9,20 / 9,50 / 10,90 / 10,60 / 9,90 / 9,60 / 59,70 / x = 47,9995 / y = 32,0000 / diff = 0,00000021 / 0,00047361
a = 9,20 / 9,50 / 10,90 / 10,70 / 9,50 / 10,10 / 59,90 / x = 47,9999 / y = 32,0002 / diff = 0,00000005 / 0,00028831
a = 9,20 / 9,50 / 10,90 / 10,80 / 9,10 / 10,60 / 60,10 / x = 48,0001 / y = 32,0001 / diff = 0,00000001 / 0,00015129
a = 9,50 / 10,00 / 9,10 / 10,70 / 10,60 / 10,90 / 60,80 / x = 48,0003 / y = 31,9998 / diff = 0,00000009 / 0,00041066
a = 9,60 / 9,70 / 9,30 / 10,80 / 10,70 / 10,50 / 60,60 / x = 47,9999 / y = 31,9999 / diff = 0,00000002 / 0,00017598
a = 9,70 / 9,10 / 10,60 / 9,60 / 10,90 / 10,90 / 60,80 / x = 47,9999 / y = 32,0004 / diff = 0,00000015 / 0,00048733
a = 9,70 / 9,20 / 10,30 / 9,90 / 10,80 / 10,90 / 60,80 / x = 48,0003 / y = 32,0000 / diff = 0,00000011 / 0,00033032
a = 9,70 / 9,30 / 9,90 / 10,40 / 10,80 / 10,50 / 60,60 / x = 48,0000 / y = 32,0001 / diff = 0,00000001 / 0,00010925
a = 9,80 / 9,00 / 10,10 / 10,60 / 10,50 / 10,60 / 60,60 / x = 47,9996 / y = 32,0000 / diff = 0,00000017 / 0,00044663
a = 9,80 / 9,10 / 9,80 / 10,80 / 10,90 / 9,90 / 60,30 / x = 48,0001 / y = 32,0003 / diff = 0,00000009 / 0,00037339
A couple of angles that work, choose the ones that you like :)
The angles are from 7 to 1. Format of a single line is:
a7 / a6 / a5 / a4 / a3 / a2 / a1 / x size of the construction / y size of the construction / eps^2 / eps
where x is the length of your red line from corner to hinge 7, y is the length of the yellow line from corner to hinge 1 (minus one), eps^2 is the sum of squares of differences (calculated x - target x)^2 + (calculated y - target y)^2, eps is the sum of absolute values of differences... I'd recommend taking a line with minimal eps (in the attached file, i used the numbers from the 3rd line from bottom). The difference between max an min angle is about 1 degree (hope that's not too much). The resolution in searching the numbers is 1/10 of degree. I can increase that, but then i'd need to optimize the program as it's already slow.
edit: attachment didn't work, i'm including a link:
http://www.pavsic.com/ldd/wall_seg.lxf
I tried with same angles a2-a7, but couldn't get even close to this results..
Edited by Bojan Pavsic, 21 March 2012 - 01:42 PM.
#7 Alasdair Ryan
Alasdair Ryan
  • Technic Hall of Fame Editor
    Member: 8292
    Country: Scotland
Posted 21 March 2012 - 01:54 PM
I am no maths genius but what about doing something like this: :classic:
Posted Image
Posted Image
Updated 10/03/15
Posted Image
#8 Rook
Rook
  • BW2013 MEGA Creation "Winner"
    Member: 2903
    Country: Canada
Posted 21 March 2012 - 03:33 PM
On angle 1 your brick is not laid the same as others thus it might be throughing off your calculations.
Bojan has an answer that I'm sure is completely correct but I don't remember enough about math to even explain it.  :blush:
If you break it down to simpler math, you basically have 7 slight angles that (if you change your hinge brick at angle 1) would equal 90 degrees (triangle equals 180 degrees minus the right angle in the corner). So you've got 90 divided by 7 equals 12.857142.  So about 12.9 degrees angle at each hinge.  :sweet: Note that is only true if you change the hinge at angle 1, as it is turned in where the other are turned out.
Edited by Rook, 21 March 2012 - 03:37 PM.
Posted Image
Signature by RΟΟK, on Flickr
#9 Bojan Pavsic
Bojan Pavsic
    Member: 9690
    Country: Slovenia
Posted 21 March 2012 - 03:55 PM
Explanation:
Each segment is the hypothenuse of a right triangle (imagine the other two cathets on the lego grid below). From that, you can calculate them:
x_part = l * cos(angle)
y_part = l * sin(angle)
The whole bounding box of the curve is just a sum of all the X parts and Y parts of all the segments... and angles sum up:
angle_7 = angle_guess
angle_6 = angle_7 + angle_guess
angle_5 = angle_7 + angle_6 + angle_guess...
First i tried with all angles the same and the best match was around 9,85 (=angle_guess). Then i changed the program to "try" values from 9 to 11 for each angle with the resolution of 0.1 degree... The results are up there.
There's only 1 catch. The first segment has pivoting points on different sides of the 1x10 brick... Which means you need to compensate that in the calculations (length is not 10 but square root of 101). There's a slight angle change because of that too, but that's just in the calculation part. The output already has that calculated in.
#10 pauldk
pauldk
    Member: 16051
Posted 21 March 2012 - 06:57 PM
Simply brilliant Bojan. I'm no math genius so you just saved my day. I just imported the model you attached and it fits perfectly. THANKS
...and everyone else, thank you very much for your replay...I appreciate your help.
Have a good one.
- Paul.
Best regards
Paul, Denmark.
The home of Lego.
#11 bbqqq
bbqqq
    Member: 14020
Posted 21 March 2012 - 07:05 PM
Maybe there is only one angles set that the arch most tan to the bottom line. (This one just close to that, for the ideal one: angle# 2,3,4,5,6 should be all the same and close to #7.)
Posted Image
angle by Nachapon S., on Flickr
Edited by bbqqq, 22 March 2012 - 12:53 AM.
42043 + BlenderGuru_Lighting_StarterScene / CS de_dust / new rooftile concept / Mr. gold concept / My new brick designs
Posted Image  Posted ImagePosted Image  Posted Image  Posted Image
YouTube Lego Pinball  YouTube Lego Bowling  My Flickr
#12 Superkalle
Superkalle
    Member: 4755
    Country: Sweden
Posted 21 March 2012 - 09:35 PM
This is intriguing Paul.
You have to let us know what it became in the end  :classic:
#13 Bojan Pavsic
Bojan Pavsic
    Member: 9690
    Country: Slovenia
Posted 22 March 2012 - 08:20 AM
@bbqqq
Yea, i thought so at first too. I even wanted to solve it analiticaly. Well, couldn't get an exact result, so i tried numericaly. Still couldn't get an "exact" (exact in quotes as it's still an aproximation because of the trigonometrical functions) result. Then i changed from a2 = a3 =... = a7 to all different, but close enough which yielded nice angles (1 decimal only as i used 0.1 degree resolution) with a mismatch at the 4th/5th decimal (which in lego AND LDD is basicly exact).
#14 DLuders
DLuders
  • Technic Technician
    Member: 7868
    Country: USA (WA State)
Posted 22 March 2012 - 01:33 PM
@ Bovan Pavsic and bbqqq:  I think I'll stick with solving easier Lego math problems, like these:   :tongue:
Posted Image
Edited by DLuders, 22 March 2012 - 01:34 PM.
#15 bbqqq
bbqqq
    Member: 14020
Posted 23 March 2012 - 07:00 AM
:tongue: This topic become a mathematic class.
We know that trial and error method is  quick and good enough way to solve this problem.
We try to find ideal angle just for fun.   :classic:
I agree with Rook that if all hinges are at the same side then it will be easier to solve.
It will become as sketch below. Use red and blue triangle can find the ideal angles set.
5 / sin A = R = 28.42973795 / sin 6A , then find angle A
Posted Image
angle2 by Nachapon S., on Flickr
Excel: 5/(SIN(B4*PI()/180)) - 28.4297379516589/(SIN((B4*PI()/180)*6))
Then trail and error cell B4 to make the result closer and closer to zero.(R-R=0, then same R)
A = 5.469182598479°
R = 52.4601998774508
Angle #2-6 = 169.061634803042°
I test this result by draw a sketch with above data and it seems correct.  :sweet:
View PostBojan Pavsic, on 22 March 2012 - 08:20 AM, said:
@bbqqq
It is difficult to keep angle #2-6 equal and keep all six segment (10x5 + 10.04987562112089027021926491276x1 :wacko:(paste from calculator):Because the first hinge is different) keep connect at the same.
Your calculation is great.  :thumbup: I will try to study them.
That is a good idea, DLuders. Just build it with real brick then measure the angles in real world. :tongue:
Edited by bbqqq, 23 March 2012 - 12:26 PM.
#16 Bojan Pavsic
Bojan Pavsic
    Member: 9690
    Country: Slovenia
Posted 23 March 2012 - 07:27 AM
I agree with simplifying the problem (changing the pivot point), but it's no good as it'll yield results, that you can't really use in LDD, because they'll be too much off.
let's say L is the segment length.
X = 48, Y = 32, L = 10, that's established from the first picture of the problem.
We need to calculate Ld (which is the diagonal of the 1 x L plate) = sqrt(L * L + 1 * 1) = sqrt (101).
a = angle between the segment (plate) and a virtual horizontal line
ad = angle of the diagonal = arctan(1 / L) = arctan (0.1)
so the rightmost segment is:
x6 = L * cos (a7)
y6 = L * sin (a7)
then following to the left 1 by 1:
x5 = L * cos (a6 + a7)
y5 = L * sin (a6 + a7)
x4 = L * cos (a5 + a6 + a7)
y4 = L * sin (a5 + a6 + a7)
x3 = L * cos (a4 + a5 + a6 + a7)
y3 = L * sin (a4 + a5 + a6 + a7)
x2 = L * cos (a3 + a4 + a5 + a6 + a7)
y2 = L * sin (a3 + a4 + a5 + a6 + a7)
x1 = Ld * cos (a2 + a3 + a4 + a5 + a6 + a7)
y1 = Ld * sin (a2 + a3 + a4 + a5 + a6 + a7)
The first angle a1 = 90 - a2 - a3 - a4 - a5 - a6 - a7, but it doesn't really matter for the calculations, just as the final hinge angle value.
if we say that the angles are the same, then we get:
X = L * cos (a) + L * cos (2a) + L * cos (3a) + L * cos (4a) + L * cos (5a) + Ld * cos (6a - ad)
Y = L * sin (a) + L * sin (2a) + L * sin (3a) + L * sin (4a) + L * sin (5a) + Ld * sin (6a - ad)
while L = 10, Ld = sqrt (L*L + 1) = sqrt(101), X = 48, Y = 32
If you want to solve this analiticaly, then you need to use the formulas for
sin (a + b) = sin(a) cos (b) + sin (b) cos (a)
sin (a - b) = sin(a) cos (b) - sin (b) cos (a)
cos (a + b) = cos(a) cos (b) - sin (a) sin (b)
cos (a - b) = cos(a) cos (b) + sin (a) sin (b)
sin^2 (a) + cos^2 (a) = 1
http://mathworld.wol...onFormulas.html
and get all the sin / cos (n * a) into sin (a) and cos (a).
This is the exact solution for the problem, no hinge side changings etc...
Maybe if matlab or mathematica or any other sw would be used, but i'm definitely not going to do that by hand :) (And it's easy expandable to different segment count.
Btw, i didn't "trial and error" it :) I did all the formulas and then just used a program to calculate the values (i didn't use any real numerical methods for solving thou, but just brute force, would take way more time and wouldn't get much better results).
Edited by Bojan Pavsic, 23 March 2012 - 07:30 AM.
#17 bbqqq
bbqqq
    Member: 14020
Posted 23 March 2012 - 09:21 AM
I found that Excel can solve the fomular very quick. My link
Edited by bbqqq, 23 March 2012 - 12:07 PM.
#18 pauldk
pauldk
    Member: 16051
Posted 28 March 2012 - 10:03 AM
So fellas.
Once again thanks for your kind help, I really appreciate that.
Some of you is probably wondering what I'm building. I'm building a church in Denmark, but I'm on a small break from the project because there's a bit to do. I will continue the project in a couple of days.
Until then, here's an image of what I have made so far.
http://dl.dropbox.co...7/Lego/lddc.jpg
Again, thanks.
Edited by Calabar, 28 March 2012 - 10:18 AM.
Oversized image converted in text link (maximum size allowed is 800x600).
Best regards
Paul, Denmark.
The home of Lego.
