I try to build the new Crawler 9398. But it is very difficult because there are not enough pictures on the net. That's what I see:
Now I need more pictures. And the new PF Motors...
Edited by Denny
Denny, you are off to a great start! Looks fantastic.
I think the two 1x11 beams in the above picture should be replaced with this part:
64178.jpg?1
The differential would be inside this, with the 12-20 reduction alongside.
Nice work you're doing here! :thumbup:
You have to remove the shocks too the right position is like in the unimog instructions, I think this set is more easy to do that unimog, the only problem are the motors :laugh:, good luck. Dhc6twinotter says the same that me in the up line but maybe better explained :sceptic: . Remove bricks and you will have room for the 5x11 liftarm structure and the diferential.
Edited by jorgeopesi
Judging by the metric ruler placed next to the chassis above, the 9398 Crawler appears to be CLOSE to the size of the 8297 Off Roader (~25 cm between the front and rear axles):
Edited by DLuders
it seems that we have searched a solution for different problems. do you think the motor above the axle is the drive motor?
Edited by efferman
It has to be. The XL motor with the axle through the center would then be the steering motor.
By powering the front and back axle with 2 M motors gives a lot more driving power.
I agree with this except that i dont thinkg the center motor is necesserily of an XL size, i think it is more of M or L type of motor.. it is interesting looking att these pictures to see that so much gearing down is made from the drive motor to the wheels.
That is why they have build a new one.
Looking at the pictures again, it looks like there are all the same.
On the box there 2 and 1, but that has to be old M motors.
I think you need to replace the middle two grey pins with two 3 long pins with centre hole, you can then mount the suspention onto them. This will give you more room.
With the M-Motor he is very slow :thumbdown::cry_sad:
We need the new Motors NOW :thumbup:
Could you invert all the gears ? The torque won't be good, but I'm curious of the total speed/torque.
