ZIL 167 all terrain vehicle
  • Please log in to reply
6 replies to this topic
#1 Nexus7
Nexus7
    Member: 7583
    Country: UK
Posted 22 January 2012 - 09:57 PM
Posted Image V-LV-54A
This truck was designed in the beginning of 1960′s. It was designed to withstand diffictult conditions in Siberia, Urals and far east and northern territories of Soviet Union. Its also able to cross water and its able to control its tire pressure, equipped with air cleaning systems and has 4,5 kw electric engine to pump water (in case of fire) and it also has radio transmission capabilities.
Wheels 6×6
Engine (2xZIL-375)
Engine displacement 2×3,5 liters
Perfomance 2×180 hp
Fuel tank capacity 900 liters
Fuel consumption 100 liters/100km
Max speed 65 km/h (on the road fully loaded)
Max speed in 50/80 cm water 30/20 km/h
Measures
Lenght 9260 mm
Width 3130 mm
Height 3060 mm
Ground clearance 750 mm
Turnin radius 11 900 mm
Weights
Cerb weight 7000 kg
Payload 5000 kg
Abilities
ability to go through obstacles:
Trench 2000 mm
Vertical wall 1000 mm
Rise angle 42 degrees
Fording 1800 mm
Snow 1000 mm
The best description I found on the net: Function follows form in every bit, styling is brutally simplistic, each bit looks like it will withstand a nuclear attack and a meteorite hit simultaneously – essentially, it’s designed to survive the apocalypse.
You can see it in action HERE
Posted Image
Posted Image
Posted Image
Posted Image
And a comparison with other trucks to give you a sense of scale.
Posted Image
#2 Henchmen4Hire
Henchmen4Hire
  • Blaster Master
    Member: 11791
Posted 22 January 2012 - 10:17 PM
Damn.
Lots of neat angles, probably lots of tricks went into building it too. Love these giant beasts, they're so ridiculous and amazing
Check my MOCPages for spiffy space ships and vehicles
Posted Image
#3 lightningtiger
lightningtiger
  • Gungans taste like chicken
    Member: 7997
    Country: Australia
Posted 22 January 2012 - 10:24 PM
That is an AWESOME vehicle 'Nexus7', looks perfect for fire fighting too ! :grin:
Excellent designing there.....Brick On Drive On ! :grin:
#4 LEGO Guy Bri
LEGO Guy Bri
    Member: 13958
    Country: X
Posted 23 January 2012 - 06:17 AM
Awesome truck 'Nexus7'. It looks very close to the real truck, very detailed. Great job   Posted Image
-I don't tell you how to tell me what to do, so don't you tell me how to do what you told me to do... I know when to use finesse
#5 JackJonespaw
JackJonespaw
  • Doesn't like cherry talk
    Member: 18405
    Country: U.S.A.
Posted 23 January 2012 - 01:08 PM
Very cool. The red color is perfect!
My Flickr
I've done a lot of Mafia games over the years. Somehow, I haven't improved at all.
Scott. Great Scott, if you will.
Working on...another...Mafia...story...
#6 Farnheim
Farnheim
    Member: 24002
    Country: Germany
Posted 23 January 2012 - 01:19 PM
Wow, this is amazing! Awesome job on that unique truck with all the different angles...
How did you do those rungs underneath the cabin. I can see two antennas holding a...? Did you shorten and cut a hose at both ends for it?
I agree with JackJonespaw, the color matches perfectly!
Farnheim
Posted Image
#7 Ecclesiastes
Ecclesiastes
  • Master of "da hood"
    Member: 17645
    Country: Holland
Posted 23 January 2012 - 05:59 PM
Sweet ride :sweet:
Got Questions? Need help? New member?
Read the site guidelines | Index of helpful tutorials | Eurobricks FAQ
Posted Image
There's a time for tearing down and a time for building. - Ecclesiastes
My Flickr
