Avalonian Siege weapon
  • Please log in to reply
4 replies to this topic
#1 Doornroosje
Doornroosje
    Member: 22814
    Country: The Netherlands
Posted 29 December 2011 - 01:33 PM
My entry for the Siege Expert title. An Avalonian Battering Ram.
Posted Image
Posted Image
(I haven't got any sand green cheese slopes (yet), so I had to use white)
Posted Image
Kariny Rhiannon Green Rider of Avalonia !
Posted Image
High King Of The Elves Lord High Chief Of Agriculture Siege Expert
#2 Legonardo
Legonardo
  • Can't Build With One Arm Tied Behind His Back
    Member: 22773
    Country: Middle Zealand
Posted 29 December 2011 - 04:45 PM
Looks great! A good addition to the Avalonian army. The white looks good with the dark green, I don't think there is any need to change it.
Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image
Legonardo
#3 Jakon
Jakon
    Member: 23492
    Country: USA
Posted 30 December 2011 - 06:36 AM
A fourth wheel on the back would look good, it looks a bit unbalanced currently, but, other than that, a great build!
Lord Jakon Rytight
Leader of the Iron Rangers, Frost Berserker
Founder of the Frozen Peaks Trading company
Posted Image
#4 ZCerberus
ZCerberus
  • Not good at planning idiot cowboy parties
    Member: 1043
    Country: USA
Posted 30 December 2011 - 06:03 PM
Very nice work LEGO Lady of Avalonia!  I do like the white and dark green like Legonardo said.  It looks very much like it was built in the field to achieve its intended purpose.
A couple of thoughts:
1) I would move the whole roof forward a bit.  It looks a little off balance with the roof extending off the back and I think it would look good going up to the fron of the ram.  I would also consider making the whol thing 2 studs wider.
2) How are we Avalonians pushing this thing?  If the whole seige engine isn't wide enough for the Avalonians to stand inside the protected area while pushing, then maybe it should have handles that extend from the sides so it can be pushed into place.
3) I don't know exactly how a batterin ram's internals work, but I would guess there is a chain or a rope that is pulled from behind the ram to pull the ram back and then once the rope is released, the ram smashes into the door or wall.  Maybe you could add that here so the ram actually works as it would in real life!
Posted Image+Posted Image+Posted Image+Posted Image+Posted Image+Posted Image+Posted Image+Posted Image
See these MOCs and MORE in the Guilds of Historica!
Trian Burress fell in Nocturnus at the battle for Abyssian!
New Member? Read This | Questions? Need Help? Ask Here
Site Guidelines | Eurobricks FAQ | Visual User Guide | Tutorials
#5 Doornroosje
Doornroosje
    Member: 22814
Posted 30 December 2011 - 09:44 PM
Thanks for your comments and suggestions for improvements.
I thought about a few myself, unfortunately I only had 6 wheels. I made the roof longer to protect the people pushing the battering ram and operating the ram, but it does look a bit out of balance now.
I tried to make it look as much as I could to medieval designs for battering rams. But it turned out to be quite a challenge.
Furthermore the wooden log hangs on chains to enable it to swing and smash the door or wall.However the space is a bit thight (a big error in my design, but when I found out I was becoming a little frustrated with the build, and just wanted it finished  :tongue: , yes I know a bit lazy, but I really wanted to go back at building houses and landscapes)
Maybe I will improve my design later with your suggestions, but I will first have to take it apart, because I need some of the parts for new builds!
Posted Image
