Removing Minifig Heads stuck tight
  • Please log in to reply
22 replies to this topic
#1 TeufelHund
TeufelHund
    Member: 15073
Posted 09 June 2011 - 06:35 AM
I recently acquired a MISB copy of Race for the Stolen Treasure (Indiana Jones) and passed all the minifig parts to my 3 year old to build for me while I built the rest of the set.
For some reason all the German Soldier minifig heads are now stuck fast to their bodies (thankfully he lined them all up pretty well with the front of the figure) yet strangely Indy's head comes free easily.
Any one else experienced this problem? I am a huge guy and no amount of basic physical tugging looks like it will do any good. I was thinking about maybe using some detergent distileld in water to loosen them but I don't want to damage the prints on the torsos. Any ideas?
#2 SlyOwl
SlyOwl
  • Watch out for Infuriated Isaac's metatarsal!
    Member: 2057
    Country: England
Posted 09 June 2011 - 09:17 AM
Pop them in hot water? It seems to be the solution to quite a lot of Lego problems!
To the barricades!
Posted Image
#3 mikey
mikey
    Member: 5926
Posted 09 June 2011 - 10:12 AM
I have had this problem when I bought older MISB sets, when they used to attach the head to the torso.  You might have already tried this, I found twisting the head loosened up the connection.  Once it is rotating nicely, then it can be pulled off easily.
my flickr
#4 Modulex Guy
Modulex Guy
  • Ain't nobody takin' my wooden fire truck
    Member: 6517
    Country: U.S.A
Posted 09 June 2011 - 10:02 PM
...but not too hot to damage the plastic.
Water that is slightly above warm works well to "loosen" the head.
NILTC
Hi, My name is Chris... and I'm addicted to Modulex.
Posted Image
O_o
I Buy Modulex!
My Flickr page.
#5 SlyOwl
SlyOwl
    Member: 2057
    Country: England
Posted 11 June 2011 - 03:28 PM
I've tried to melt Lego on numerous occassions - and the only successful time was with a naked flame (don't worry, I did it to an already broken piece!). Boiling hot water, right under a desk lamp + magnifying glass - no avail!
I did put a ribbed hose in hot water once (it's made from a softer plastic) - it lost some definition, but nothing too bad.
To the barricades!
Posted Image
#6 Jargo
Jargo
    Member: 10639
    Country: Brickish isles
Posted 11 June 2011 - 04:07 PM
WD40 or some other oil type solution. If it'll work for stuck tight nuts and bolts it'll work on stuck tight lego bricks.
#7 Modulex Guy
Modulex Guy
    Member: 6517
    Country: U.S.A
Posted 12 June 2011 - 03:22 AM
I would not use that on LEGO, the stuff has a harsh smell and it is almost impossible to get off.
NILTC
Posted Image
O_o
I Buy Modulex!
My Flickr page.
#8 prateek
prateek
  • Study hard!
    Member: 426
    Country: Canada
Posted 12 June 2011 - 05:52 PM
Just use pliers to yank it off, but make sure to use padding so the head doesn't get damaged.
#9 brickmack
brickmack
    Member: 12146
    Country: America
Posted 12 June 2011 - 06:46 PM
Sometimes I use those rubber grip things used for removing stuck bottle caps, but you have to be careful not to rub off the printing. Sometimes with new sets the heads get stuck on, and the only way to be sure it doesn't happen is to slowly push the head down when you are first putting it on, while twisting it in alternating directions.
Hot water won't melt LEGO, but I think it will make it brittle over time.
#10 Red Bricks
Red Bricks
    Member: 17178
    Country: Great Britain
Posted 21 June 2011 - 08:29 PM
Hot water would do it, Never use soap, it severely deforms your minifigure, That takes me back to 2007  :laugh:
#11 Devorath
Devorath
    Member: 32747
    Country: NZ
Posted 22 April 2013 - 12:43 AM
I placed the new SW Trooper head inside the CMF Gorrilla 'hat' piece, and now it's stuck. Does anyone have a way to get a minifigure head out? I have tried twisting the head, and trying to pull the head out, but I did these to no prevail. I would like some suggestions, as I want to use the head for a Gambit minifigure.
Thanks :classic:
removed link to removed flickr image
             Credit to Carousel for the banner!
#12 Spitfire2865
Spitfire2865
    Member: 35687
    Country: United States
Posted 22 April 2013 - 01:02 AM
Put a brand new torso on it? and then pull?
Or maybe use some sort of tool like tweezers.
Growing Old is Mandatory, Growing Up is Optional. -Anonymous
#13 LegoCityMann
LegoCityMann
  • 90 year old scientist
    Member: 17769
    Country: USA
Posted 22 April 2013 - 01:12 AM
Use a Technic pin or a Technic beam, usually works for me.
Stoneford: My Modular Town Where I keep a running thread about my modular town, new buildings, and changes to old ones.
#14 Boxerlego
Boxerlego
    Member: 34903
Posted 22 April 2013 - 01:52 AM
Needle nose pliers work great.
#15 Young Leo
Young Leo
    Member: 29250
    Country: Canada
Posted 22 April 2013 - 02:31 AM
You could also try sticking the head-hat onto the neck of another minifigure and try pulling it off that way. I did it a couple times for my hoods.
Beneath the gold, the bitter steel.
#16 Sid Sidious
Sid Sidious
    Member: 20847
Posted 22 April 2013 - 02:34 AM
If you use pliers, try putting a piece of cloth over the tips so the head isn't scratched mercilessly.
#17 costabkz
costabkz
    Member: 49303
Posted 22 April 2013 - 03:02 AM
Needle nose pliers work great.Posted Image
#18 Spider-Man
Spider-Man
    Member: 29489
    Country: USA
Posted 22 April 2013 - 03:03 AM
This!! I have damaged one head too many that way :cry_sad: Luckily they weren't ever really important ones...
Courtesy of your friendly neighborhood Spider-Man!
Posted Image Posted Image
flickr
#19 obsidianheart
obsidianheart
    Member: 20007
Posted 22 April 2013 - 03:13 AM
I once saw a tutorial where a guy would put a technic pin in the neck socket, then put a lightsaber blade type bar in the technic pin. The one time I tried it (with a 3rd party helmet, though), it didn't work, so your mileage may vary.
#20 Saint
Saint
  • Holy Crap that's a CTT
    Member: 1974
    Country: Netherlands
Posted 22 April 2013 - 09:43 AM
Put it on a torso, create a little bit of friction ( like snapping it half , but not so drastic ) and pull the helmet ( or gorrilla head ) off. Works for me .
grtz Saint
~Mr Holy Crap that was fast!~
visit my brickshelf
My flickr
Clone Turbotank
Posted Image
#21 A2L
A2L
    Member: 17201
Posted 23 April 2013 - 05:58 AM
For me the cotton bud works very well. I just insert it and push it out genly at an angle. The head comes out neatly without damage or scratches. You have to use the full cotton buds, not the thin soft ones for babies. I use J&J.
#22 Brickdoctor
  • Look at my Post Count!
    Member: 11254
    Country: California, USA
Posted 23 April 2013 - 06:03 AM
That's what I do, too. I did have one head once that was particularly tough to get out: I'd put a Vader head (Chrome Vader's if it makes any difference.) into the helmet of the CMF S9 Knight, and couldn't get that one out. Ended up using a Technic axle and wiggling it around a bit, and then tried again with the torso, wiggling it again before doing the "bend and pull" method Saint described, and it came out fairly easily. (I used a Technic axle and not a pin because the axle can be slid in and out without creating enough friction to push the head back in if you've gotten it a little bit out. That effect was avoided when I went back to using the torso by twisting the torso as I eased the neck pin back into the head.)
#23 ronnyyun
ronnyyun
    Member: 49665
Posted 24 April 2013 - 03:35 AM
Use a Technic pin or a Technic beam, usually works for me.Posted Image
