On this
, Nico71 (Nicolas Lespour) shows "A simple assemby to test different BB [battery boxes], based on differential principle.
-- If the yellow part turns clockwise, the slowest motor is on the right
-- If the yellow part turns anti-clockwise, the slowest motor is on the left
http://www.nico71.fr ."
Very cool! This would definetly help me. I hope they make instructions for it though.
Hello, do you need instruction ? Because I make the video to show you how to build this but if you need some other picture, I can do it :)
As Zblj has pointed out : you can also compare two identical motors with pluging the two motor on one battery box. :)
  • 5 weeks later...
I would also try running both off one battery just in case one motor runs slower than the other. It would be annoying for that to be the problem.
Yeah, it's a good idea but you'd either need to be sure that the motors are identical (are they normally? :look: ) or repeat the test with the motor reversed just to be sure.
