Superkalle Posted April 3, 2011 Posted April 3, 2011 UPDATE January 2012 There is no longer any need to manually unlock the Extended Mode - it is available to all users when simply installing LDD Unlock all the bricks in LDD with LDD Extended Mode (This information by kind permission of the LDD Development Team in Billund) With the release of LDD 4.1 comes a new mode - LDD Extended - that you need to manually activate. So what about the "old" Lego Universe mode? Well, it is now activated for all users out-of the-box - no need to edit the preferences.ini file to see it. However (and this is important), the new Universe mode does not have all the bricks we are used to. Luckily, the LDD Team in Billund (thanks guys!) have thought about us more hardcore LDD fans and has given us LDD Extended mode which again unlocks all bricks. Also, please be aware that LEGO is making LDD Extended mode available to us LDD fans as-is. LEGO takes no responsibility for this mode and there is no support available. How to unlock LDD Extended mode Please do NOT re-post this information on the internet. Instead, link to this post. Thank you. For windows users 1. Close down LDD 2. Find the file preferences.ini the LEGO Digital Designer folder. For Windows 7 and Vista it can be found here C:\Users\UserName\AppData\Roaming\LEGO Company\LEGO Digital Designer\preferences.ini For Windows XP here: C:\Documents And Settings\UserName\ApplicationData\Lego Company\Lego Digital Designer\preferences.ini NOTE: If you can't find this folder, the read here how to make it visible OR simply enter %appdata% into the Explorer address bar (or Start menu search box) which will automagically open the right place (thanks Andy for the tip) 3. Open preferences.ini in a text editor and add the line: ThemeAccess=LDDExtended 4. Save the file 5. Restart LDD and now you have access to LDD Extended Mode For mac users. 1. Close down LDD 2. Find the file preferences.ini in /User/Library/Application Support/LEGO Company/LEGO Digital Designer/preferences.ini 3. Open it in a text editor and add the line: ThemeAccess=LDDExtended 4. Save the file 5. Restart LDD and now you have access to a LEGO Universe palette Regarding LION on the Mac (thanks to Vynsane for the info) With this newest release of the Macintosh Operating System, the "Library" folder in each individual "User" folder is hidden by default. You will first need to unhide it in order to access the directory structure "{hard drive name}/Users/{user name}/Library/Application Support/LEGO Company/LEGO Digital Designer/preferences.ini" Open Terminal (via the 'Go' menu when in Finder and selecting 'Utilities', then double-clicking 'Terminal') and type the following (replace {user name} with your actual user name): chflags nohidden /users/{user name}/library This will unhide that directory, allowing you access to the folders therein, including the files necessary to activate 'Extended Mode' per above. Want to discuss Extended Mode? Go HERE to discuss Extended Mode, questions, issues, problems etc. ================ Extended Mode Q & A Q: If I activate LDD Extended mode, will LDD still automatically update over the internet when a new version is released? A: Yes Q: If I design in LDD Extended mode, will the model also open with LDD on computers that do not have this mode activated? A: Yes Q: Does Lego offer any end-user support on Extended mode? A: No Q: Are all colors available in LDD Extended mode? A: Well most of them. Unlike for the other modes, there is a Legacy section with a selection of discontinued colors. Quote
Superkalle Posted April 4, 2011 Author Posted April 4, 2011 STOP Do not post in this topic Instead please discuss the Extended Mode here And please discuss the new LDD 4.1 release in general here And report brick bugs here Thanks! Quote
vynsane Posted August 12, 2011 Posted August 12, 2011 (edited) I know it says not to post here, but this isn't a bug, discussion of LDD 4.1 or of discussion of 'Extended Mode' - it's a new step in the procedure required to activate 'Extended Mode' in OSX 10.7 "Lion". With this newest release of the Macintosh Operating System, the "Library" folder in each individual "User" folder is hidden by default. You will first need to unhide it in order to access the directory structure "{hard drive name}/Users/{user name}/Library/Application Support/LEGO Company/LEGO Digital Designer/preferences.ini" Open Terminal (via the 'Go' menu when in Finder and selecting 'Utilities', then double-clicking 'Terminal') and type the following (replace {user name} with your actual user name): chflags nohidden /users/{user name}/library This will unhide that directory, allowing you access to the folders therein, including the files necessary to activate 'Extended Mode' per above. Superkalle - feel free to include these steps in your original post and delete this one if deemed necessary. Edited August 12, 2011 by vynsane Quote
Superkalle Posted August 12, 2011 Author Posted August 12, 2011 I know it says not to post here, but this isn't a bug, discussion of LDD 4.1 or of discussion of 'Extended Mode' - it's a new step in the procedure required to activate 'Extended Mode' in OSX 10.7 "Lion". Excellent Vynsane, thanks for the headsup! Quote
deleus Posted September 10, 2011 Posted September 10, 2011 Thanks for this post..i tried to edit preferences.ini...but it always gives me "access denied"..maybe i do some mistakes...please let me know thanks Quote
legofan1208 Posted September 18, 2011 Posted September 18, 2011 I realy need your help. When I try to save the preferences, it says Accese Denified. Please respond. Quote
AndyC Posted September 18, 2011 Posted September 18, 2011 I realy need your help. When I try to save the preferences, it says Accese Denified. Please respond. You are almost certainly editing the wrong preferences file. You should be editing the one within your user folder, not the one in the Program Files directory. Quote
hrontos Posted September 18, 2011 Posted September 18, 2011 You are almost certainly editing the wrong preferences file. You should be editing the one within your user folder, not the one in the Program Files directory. Easiet way to get to right folder is to type %appdata% in windows explorer addres bar. Look for the LEGO Company folder there. Or type %appdata%\LEGO Company\LEGO Digital Designer. Quote
primitiv Posted November 6, 2011 Posted November 6, 2011 (edited) Thanks for this post..i tried to edit preferences.ini...but it always gives me "access denied"..maybe i do some mistakes...please let me know thanks This normally occurs when the file being edited is write-protected. The easiest solution to this is to save the file as "preferences.ini" and save it in a different location, for example on your desktop, and then simply copy this file into the LEGO directory. Edited November 6, 2011 by primitiv Quote
deleus Posted November 7, 2011 Posted November 7, 2011 This normally occurs when the file being edited is write-protected. The easiest solution to this is to save the file as "preferences.ini" and save it in a different location, for example on your desktop, and then simply copy this file into the LEGO directory. thanks :)...i solved it a while back...ready to make some projects now..:) Quote
groomy1978 Posted November 16, 2011 Posted November 16, 2011 Hello everyone i'm new here. Was hoping that someone could help with LDD. I have just gone over to Mac for the first time and I am trying to get LDDExtended to work. I have followed the instructions above including the addition for LION but nothing seems to be working. The response that i get from adding the no hidden library is this: usage: chflags [-fhv] [-R [-H | -L | -P]] flags file ... I have no idea if this means that i has worked or not as I unfortunately haven't got a clue when it comes to computers. Hope that somebody can help. Tom Quote
vynsane Posted November 16, 2011 Posted November 16, 2011 Tom - you're replacing the text {user name} with your actual username, right? So if your login username for the Mac OS is Tom, you would use chflags nohidden /users/Tom/Library To check if it has worked, you would then open your OS hard drive (default name is 'Macintosh HD' on the desktop) and click 'Users' - > {user name folder} (in this case the theoretical 'Tom' folder, which should look like a house) and see if the folder 'Library' is visible. If it is, you can the follow the rest of the directions as posted. I tested this a bit and you may have hit 'return' after typing in the chflags command, before the 'nohidden...' part. Thats when I got the 'usage:' line: When I typed in JUST 'chflags' and hit 'return' - make sure you type it in on one line exactly as I posted above (replacing 'Tom' with your actual username). Quote
groomy1978 Posted November 16, 2011 Posted November 16, 2011 Tom - you're replacing the text {user name} with your actual username, right? So if your login username for the Mac OS is Tom, you would use chflags nohidden /users/Tom/Library To check if it has worked, you would then open your OS hard drive (default name is 'Macintosh HD' on the desktop) and click 'Users' - > {user name folder} (in this case the theoretical 'Tom' folder, which should look like a house) and see if the folder 'Library' is visible. If it is, you can the follow the rest of the directions as posted. I tested this a bit and you may have hit 'return' after typing in the chflags command, before the 'nohidden...' part. Thats when I got the 'usage:' line: When I typed in JUST 'chflags' and hit 'return' - make sure you type it in on one line exactly as I posted above (replacing 'Tom' with your actual username). Thank you, yes i was replacing it with my user name (tom), but that wasn't working. I kept trying and for a some reason it worked, i can't see what i did different but at least its working now. Many thanks Tom Quote
vynsane Posted November 17, 2011 Posted November 17, 2011 Odd... Well, I'm glad it worked in the end. Quote
MarqueIV Posted November 19, 2011 Posted November 19, 2011 Just a heads-up for Lion users... an even easier way to get to the library is to simply hold down the Opt/Alt key when the 'Go' menu is expanded. When held down 'Library' will appear in the list... no Terminal needed! Quote
Dakar A Posted November 25, 2011 Posted November 25, 2011 Help! I've done everything here, I am using windows, I edited the text under users, I also pressed enter and started a new line when I added extended mode. What am I doing wrong? Quote
Superkalle Posted November 25, 2011 Author Posted November 25, 2011 Help! I've done everything here, I am using windows, I edited the text under users, I also pressed enter and started a new line when I added extended mode. What am I doing wrong? Did you exit LDD first, edit the ini-file and then restart? Most often when people have problems with activating Extended Mode, it's because they missed some part of the instruction. Quote
