Importing LDR to Poser usable file.
  • Please log in to reply
1 reply to this topic
#1 Supa
Supa
    Member: 13971
Posted 29 October 2010 - 10:06 AM
Hello everybody,
I'm trying to import a bunch of LDR models into Poser 7. Unfortunately, I can't get a workable result. This is how I tried to do it. With some luck, I hope you'll be able to see what went wrong or direct me to a better option.
I created the model in MLCAD 3.30 and I saved it in a LDR file.
I opened it with LeoCAD 0.75.1 and exported it to 3D Studio format.
With Poser 7, I import the 3DS model with the following settings. And here I've got a problem : A lot of the vertexes are inverted. I can see them when I import the same file with 'Flip normals' option checked. The same happens if I export my LDR model in Wavefront OBJ format.
Posted Image
Posted Image Posted Image
LdrDat2Obj produces worse results, with an exploded model.
Posted Image
Converting the LDR file with 3DWin5 5.6c to 3DS or Wavefront OBJ with the following settings doesn't help :
Posted Image
This is the first time I've got problems to import a 3DS or OBJ file to Poser.
Thanks for any help you can provide. :)
Edited by Supa, 29 October 2010 - 10:15 AM.
#2 Shroud
Shroud
    Member: 10165
    Country: Australia
Posted 30 October 2010 - 01:04 AM
I managed to import models into Lightwave from MLcad and they worked fine. Only problem was they were all individual objects and slowed my system down pretty bad
Posted Image
