My five small Cutters
  • Please log in to reply
19 replies to this topic
#1 Cherno
Cherno
    Member: 13634
    Country: Germany
Posted 07 October 2010 - 06:12 PM
UPDATE 11-26-2010: See more, newer pictures below!
Greetings, fellow buccaneers.
I recently got gripped by the Lego pirate fever (again, after storing all the sets in the attic as a teenager, some 15 years ago) and decided to build a fleet to play the famous Evil Steve's Pirate Game (ESPG).
I started with some smaller ships, so-called cutters, because they are fairly easy to build and don't need too many parts. In ESPG, every ship has a certain class which determines the damage it can take and the number of cannons it can mount.
The classes are (copied from the ESPG site):
0 - Boat (a canoe, rowboat or sailboat, or longboat)
1 - Cutter
2 - Brig
3 - Regular ship with 1 center section, or wide ship with no center sections.
4 - Regular ship with 2 center sections, or wide ship with 1 center section.
5 - Regular ship with 3 center sections.
6 - Wide ship with 2 center sections.
7 - Wide ship with 3 center sections.
8 - Wide ship with 4 center sections.
Players will start with a Class 2 Ship (Brigs, of which I have only one built so far; think of the brilliantly designed merchant vessel that is inluded in the Imperial Outpost Set). The smaller Class 1 Ships (Cutters) will be used as cheap Mission-Runners and maybe attack vessels if they can swarm the enemy.
I have built five Class 1 Cutters so far. All five where made from parts a had in my big pile of Lego parts, so I didn't have to buy any special parts. From a design standpoint, I had three goals in mind:
1. An overall rugged construction, so that the ship doesn't break in half when handled roughly while in the heat of battle
2. A color scheme which sets the ship apart from others in it's class and makes it easily identifiably on the wide, blue "carpet ocean" ;)
3. A certain eyecatcher at the ship's bow, so that the stern section (which, of course, is always bigger, higher and has an overall more complex construction than the rest of the ship) doesn't dominate the whole vessel from a viewing standpoint.
That being that, I present you my five custom-built little Cutters. Note that I currently don't have any special masts, so I had to made due with substitutes, and three of the cutters have no rudder and flag. Also, cannons of any sort are missing. I will probably add those once I have constructed enough, as the proper Lego pirate cannons look far too big on these smallish ships, even though they can only mount 1 per their class. A big "thank you!" goes out to Evil Willy for his "Making Sails" tutorial. Bigger pictures are available by clicking on the photos.
1. The "Stinger"
This is the first cutter I built. The hull is constructed from white parts of a jetliner fuselage (a very old Lego set, most likely from around 1990). The Color white is very prominent here, with black for the deck, masts and railing. It is one of the two smaller cutters I constructed, being relatively short and with a low deck and stern. The "bow gimmick" here are two lance-like ramming devices pointing to the Stinger's front. I'm not sure which function these would have, but I thought they looked cool.
Posted Image Posted Image
2. The "Golden Crown"
A majestic name for a majestic ship. The "Golden Crown" is longer and higher than the "Stinger", partially due to it's two-level deck.The yellow elements and especially the ornamental railings invoke a feeling of certain royalty. To the ship's front are two black outward-facing handles acting as a special kind of railing as well as two small yellow torches. A perfect luxury vessel for the governour's spoiled son Sir Eric la Douche, seen standing on the ship's stern with a goblet of fine french wine in his hand. Pity the captain of the Admiral's Guard who has to keep a watchful eye on that brat.
3. The "Bloody Sabre"
A sleek, agressive-looking raider of the crimson seas. Because it has four portholes on each sides, the "Bloody Sabre" looks very long for a ship of it's class, even though it's only one stud longer than the "Golden Crown". The cutter's name derives from two stern-mounted sabres pointing upwards (you can't ever have enough sabres!). The stern also has two tall torches acting as a kind of deterrent to would-be buccaneers trying to attack this fearsome ship at night. I plan on mounting two forward-facing sabres on the ship's bow, where at the moment only two "devil's horns" feature somewhat prominently.
Posted Image
4. The "Swansong"
This ship's long, flowing lines and the purity of it's color scheme (everything apart from the masts, the railing and the decks, as with the "Stinger", is white) reminded me of a mystic ship commandeered by benevolent spirits of long forgotten seafarers. Anyway, the "Stinger"'s bigger brother is the longest cutter I have built thus far; The triple-piece bow adds another three studs over the "Bloody Sabre"'s 21. Mounted on the stern is a rearward-facing, hinged flagpole which makes the "Swansong" even longer. I am a little perplexed about the bow, though; two torches are mounted dangerously close to the ship's main sail! I sure hope they brought the fireproof canvas from Port Brick...
5. The "Dolphin"
Similar in size to the "Stinger", I only chose the somewhat uncreative name "Dolphin" because "Little Blue Ship" sounded even worse. The "Dolphin is the weakest design I have come up with thus far, partly because blue just isn't the nicest color to have for a ship. Also, it isn't really gimmicky; a (unsurprisingly blue) ladder is hung from either side below the sterncastle, and to the front we have a weird, blocky piece from who-knows-which-set. Overall, I think the design is acceptable if it weren't for the dominant blue. I might rebuilt the "Dolphin" (which of course would need a new name, then) in another, more pleasant color.
My Cutter Fleet
So this concludes my latest building session. Please feel free to post your comments.
Happy pirating,
Robert
Edited by Cherno, 26 November 2010 - 04:56 PM.
#2 Zorro
Zorro
  • Farewell Dieter!
    Member: 3951
    Country: Belgium
Posted 08 October 2010 - 01:16 AM
Looks like a nice small fleet suited for it's purpose.
I'm also having the impressions people are starting to talk more again about Evil Stevie's Pirate game lately. Am I alone in this?
#3 Mrlegoninja
Mrlegoninja
    Member: 11901
    Country: United States
Posted 08 October 2010 - 01:18 AM
Pretty great! :pir-cry_happy:
Posted Image Posted Image Posted Image Posted Image Posted ImagePosted Image
Murdered Day 8 as former Armed Forces member and Spider ward member Dudley Eisenhower in Def's Doctor Bloodbrick's Asylum.-Insane
Thank you Jebediahs for that great paper doll!
Died as Congressman Aide Maxwell Touns in Bob's Red Scare Mystery-Town
Died as Pub Owner Mrs. Le Goninja in Def's The Coming Darkness-Town
Died as Pet Store owner Jack Montgomery in Bob's Suburbia
Currently playing as the 40 year old teller Richard Sexton in Hinckley's Red Moon Two!
#4 Big Cam
Big Cam
  • No good dead ever goes unpunished.
    Member: 5701
    Country: USA
Posted 08 October 2010 - 02:49 PM
Welcome to the forum, what a great first post.
I really like your collection of clippers, for some reason they remind me of Jack Sparrows boat that he gracefully rides in at sinking speeds to the dock.
Great work, and welcome.
#5 Cherno
Cherno
    Member: 13634
    Country: Germany
Posted 08 October 2010 - 04:11 PM
Thank you all for the kind words. I will be adding some bigger ships in the near future.
Oh, and sorry about the mediocre picture quality. I saw that thread about making better photos one day too late  :pir-hmpf:
Edited by Cherno, 08 October 2010 - 04:11 PM.
#6 jmp_smarty
jmp_smarty
    Member: 14248
Posted 17 November 2010 - 02:48 PM
can ya sell me the dolphin for $10?
including full parts and instructions?
i am in Butuan City, Philippines 8600
#7 Big Cam
Big Cam
    Member: 5701
    Country: USA
Posted 17 November 2010 - 04:48 PM
No problem, they are pretty good, I wouldn't worry about it.
:pir-sceptic:  Did he say they were for sale?
#8 Cherno
Cherno
    Member: 13634
    Country: Germany
Posted 17 November 2010 - 08:56 PM
The ships are not for sale, sorry. I might post some better pictures showing a detailed construction analysis in the future, though. Currently the "Dolphin" isn't my fleet's ugly duckling anymore, as I changed the black bricks with white, and it's looking a lot better now!
As a side note, my fleet has been expanded massively, with one additional clipper, six Brigs based on the Imperial Trading Post's ship/boat and no less than ten bigger ships of different sizes. I am currently making sails for them all. Stay tuned for loads of picture soon :)
#9 Big Cam
Big Cam
    Member: 5701
    Country: USA
Posted 17 November 2010 - 09:50 PM
View PostCherno, on 17 November 2010 - 08:56 PM, said:
My fleet has been expanded massively, with one additional clipper, six Brigs based on the Imperial Trading Post's ship/boat and no less than ten bigger ships of different sizes. I am currently making sails for them all. Stay tuned for loads of picture soon :)
I can't wait!
#10 jmp_smart
jmp_smart
    Member: 14291
Posted 19 November 2010 - 12:13 PM
ok.
by the way can ya tell me how to make it?
it kind'a looks cute
look at mine (inspired by yours
*update:
this is jmp_smarty's backup account
#11 Cherno
Cherno
    Member: 13634
    Country: Germany
Posted 19 November 2010 - 02:22 PM
View Postjmp_smart, on 19 November 2010 - 12:13 PM, said:
ok.
*update:
I reconstructed the Dolphin with Lego Digital Designer, here is the model file:
http://rapidshare.co...r_1_dolphin.lxf
Note that it already has the changed color scheme i talked about earlier in this thread (white instead of black), and i designed new masts which are closer to the original Imperial Trading Post Brig's mast. Also, since i couldn't find three parts at the ship's bow, here are the part numbers that are missing from the model in the LDD file:
6104 Wing 8 x 8 with 3 x 4 Cutout
4276b Hinge Plate 1 x 2 with 2 Fingers and Hollow Studs
4319 Hinge Bar 8 with Split Bar Holder (new mast, differs from the photos in this thread)
Have fun and feel free to ask any questions!
#12 jmp_smart
jmp_smart
    Member: 14291
Posted 19 November 2010 - 02:40 PM
Thanks Cherno.
Though how did ya get the sails?
mine is just a lego sail.
btw thanks.
well at least i have the only cutter with a rope running the full length of the ship...
#13 Sinner
Sinner
  • Hinck's bazzar boy
    Member: 1554
    Country: Australia
Posted 19 November 2010 - 03:04 PM
*update:
Oh yes, we chambered the last account by mistake so there's no reason why we'd mind you creating another.  :pir-hmpf:  Ooops, looks like it's going to happen again.
Full details on the Siegfried About Me page!
#14 Cherno
Cherno
    Member: 13634
    Country: Germany
Posted 19 November 2010 - 03:20 PM
View Postjmp_smart, on 19 November 2010 - 02:40 PM, said:
Thanks Cherno.
btw thanks.
Even though i don't know what's going on, i'll just answer the question regardless.
The sails you can see on the pictures are just cut out from fabric after measuring the required size. As of now, however, i use self-made copies of the small sails from the ITP Brig and Raft Raiders set. That also means i don't have to use as much fiddly string as the sails are designed to go straight over the (cross)masts.
#15 Cherno
Cherno
    Member: 13634
    Country: Germany
Posted 26 November 2010 - 03:57 PM
Update:
In the last few weeks, i managed to build  and complete my fleet of cutters and brigs. The sails are all custom-made.
Standing on my cupboard are several larger ships which still need sails, so that will take another week or two until they're ready for the high seas. Stay tuned for more updates soon(ish).
Edit: Almost forgot, special thanks go out to Matteo1130 for his Simple cannon design and, of course, Evil Willy  for his Tutorial on making sails.
Arrr!
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Bonus picture: KRAKEN ATTACK! ("It just wants to play...!")
Posted Image
Edited by Cherno, 26 November 2010 - 05:07 PM.
#16 Dread_Privateer_Roberts
    Member: 16410
    Country: USA
Posted 01 April 2011 - 09:37 PM
Great little boats!
Thanks for the ispiration, I need to build a few like these. My gaming fleet is heavy on the 12 and 16 hull ships, but kinda skimpy on the 4 and 6 stud hulls...
There comes a time in most men's lives where they feel the need to raise the Black Flag.
#17 b0bb33z3r
b0bb33z3r
    Member: 16928
Posted 06 April 2011 - 07:17 PM
that makes 2 of us, seriously need to get some parts together and build some smaller cutters.
nice work!
#18 Cpt. Tristan
Cpt. Tristan
    Member: 19882
    Country: USA
Posted 29 August 2011 - 02:09 AM
Wow, that's pretty cool (and cute). That actually inspires me to build my own fleet, although all imperial.
Yes i've noticed that too.
Nothing is truly weird, just interesting and different is a unusual way. -Me
Posted Image My Flickr Posted Image
Posted Image
#19 Sebeus I
Sebeus I
  • Winner of the Third Tournament of Retribution!
    Member: 3891
    Country: Belgium
Posted 29 August 2011 - 11:36 AM
That a nice fleet you have there, Personnaly I find the ESPG too complicated to play, I believe someone around here made an easier version where he used a grid so it's less complicated to move around ships
#20 Frank Brick Wright
Frank Brick Wright
  • Baby Minifigure
    Member: 20080
    Country: Portugal
Posted 19 September 2011 - 09:06 AM
Small and accurate! Good job!
A ship is floating in the harbour now,
The wind is hovering o'er the mountain's brow;
There is a path on the sea's azure floor,
No keel has ever ploughed that path before
(Percy Bysshe Shelley)
MOCPages account, Flickr and Brickshelf
