Remote Controlled Trike
  • Please log in to reply
14 replies to this topic
#1 Jurgen Krooshoop
Jurgen Krooshoop
    Member: 9323
    Country: The Netherlands
Posted 07 September 2010 - 09:22 PM
For the next Allround Car Competition, the theme is "All But Four", meaning all contestants have to make an RC-vehicule with any number of wheels exept 4. Since building light is a good technique to make a fast car, I chose the minimum number of wheels with which is was possible to make an RC-car: 3.
To give it good driving capabilities, I wanted to include the following:
* Make it as light as possible
* Differential for smooth cornering
* Good steering-lock for good manouvrability
* Return-to-centre steering for comfortable controll
Posted Image
And to give it just a bit extra than just an RC-vehicule, I included a working V4-engine. It also has front & rear-lights.
For the return-to-centre steering, this part was used. It has an internal spring, which returns an axle to neutral position. An M-motor was used. Different gear-setup were tested to find the one with the best steering-lock/Return-to-neutral performance. Te result is a very manouvrable trike.
For propulsion, I chose an XL-motor. It's speed was increased by a factor 2 in a drivetrain comparable to my E.R.T.W.D.. It is quite fast, while still having some power to drive over some obstacles.
Again, I made full building instructions so all you Trike-lovers can build your own. The instructions can be downloaded on my website www.jurgenstechniccorner.com. I made some nice renders from the ML-Cad model:
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Edited by Jurgen Krooshoop, 31 October 2010 - 02:46 PM.
#2 TechnicJuan
TechnicJuan
    Member: 3775
Posted 07 September 2010 - 09:45 PM
That is actually really cool.  :thumbup:
#3 Zblj
Zblj
    Member: 7054
    Country: Slovenia
Posted 08 September 2010 - 07:18 AM
Now this is awesome! You sure amde a great challenge for other builders  :classic: One tip, replace knob gears with nomral bewel gears, because the knob gears are quite jerky, you will gain with nomral bewel ones.
#4 Jurgen Krooshoop
Jurgen Krooshoop
    Member: 9323
Posted 08 September 2010 - 07:42 AM
Thanks, I'll try bevel gears instead of knob gears. It drives very nicely now with the knob gear, but all improvementa are welcome.
#5 Jetro
Jetro
    Member: 4145
    Country: Spain
Posted 08 September 2010 - 10:52 AM
A beauty and with an original steering mechanism to boot. Love it!
Edited by Jetro, 08 September 2010 - 10:53 AM.
#6 Jurgen Krooshoop
Jurgen Krooshoop
    Member: 9323
Posted 09 September 2010 - 09:56 AM
Ok, I replaced the knob-gears with normal bevel gears, but the performanche didn't improve. Now I even switched back to knob-gears, because the bevel gears had the tendency to skip sometimes, which deccreases performance a bit. And I really don't like skipping gears. And the knob-gears did't have that problem in this model.
#7 Zblj
Zblj
    Member: 7054
    Country: Slovenia
Posted 09 September 2010 - 10:20 AM
Okay, I just thought it might help  :thumbup:
#8 freakwave
freakwave
    Member: 9247
    Country: Austria
Posted 09 September 2010 - 10:30 AM
Great Trike! I like the cornering it does!
One thought: Isn't it crunching gears when you do the wheelie? Doesn't the differential cry a bit when you revers the XL Motor?
fW
#9 dolittle
dolittle
    Member: 12702
Posted 09 September 2010 - 07:10 PM
Truly amazing, as the rest of your designs.
I asked this before, but it didn't work out :)
Can you provide a list of parts in a text file with the corresponding part numbers?
The picture based list is very hard to match against what I have available, especially with the more complex parts which apparently I don't have :)
#10 Blakbird
Blakbird
  • Technic Angel of Retribution
    Member: 2164
    Country: USA
Posted 09 September 2010 - 08:22 PM
The picture based list is output by LPub automatically, so it doesn't require any extra work for him to make it. A text based list would be a lot of effort on Jurgen's part. If you want more detail, I recommend downloading the LDraw file and exporting your own parts list from either MLCAD or LDView. Both will have part numbers attached, although these part numbers do not always match the numbers in Bricklink.
Blakbird
Technicopedia
#11 Jurgen Krooshoop
Jurgen Krooshoop
    Member: 9323
Posted 09 September 2010 - 10:07 PM
And your help is much appreciated, that's why I tried it. In different setups it might work better eg when I use the new gear-boxes from the new 8043 excavator.
fW
It drives quite smooth, no gears are skipping even when I drive it forewards-back-forewards quickly.
As Blakbird mentioned, making a Bricklink-parts-list is a lot of work. And making good-looking instructions already takes a lot of time to make (more time than designing the model in this case) which delays future MOC-projects.
The parts-list image from the instructions were made smaller to fit on the page. I could provide you with a much larger and clearer image from the parts list if you want. You can mail me at Jurgenstechniccorner -a- hotmail.com (replace -a- with @ ).
The original MLCad/LDraw-file can be downloaded from my corresponding MOC-page.
Edited by Jurgen Krooshoop, 09 September 2010 - 10:10 PM.
#12 CP5670
CP5670
  • In search of litmus paper
    Member: 2646
    Country: United States
Posted 10 September 2010 - 05:05 AM
This looks great. It's like an upgraded 8857. :thumbup:
#13 Jurgen Krooshoop
Jurgen Krooshoop
    Member: 9323
Posted 10 September 2010 - 05:50 PM
Yes, it looks a bit like the 8857, but I don't have that set and it wasn't an inspiration source, so it's pure coincidence.
#14 allanp
allanp
    Member: 961
    Country: UK
Posted 10 September 2010 - 07:03 PM
That thing handles well, love the wheelies and the tight, return the centre steering. Not quite sure about the colour scheme but it looks alot of fun to play with.
Edited by allanp, 10 September 2010 - 07:04 PM.
Even the best can be made better, but most important is to be excellent to each other and party on dudes!!!!!!
#15 grohl
grohl
    Member: 11368
    Country: Czech Republic
Posted 10 September 2010 - 07:37 PM
The performance of this MOC is really astonishing. Great job on that.
YouTube   Facebook BrickShelf  Flickr
I know the pieces fit.
