Problem with PF trains ?
8 replies to this topic
#1 The Yellow Brick
The Yellow Brick
    Member: 11404
    Country: England
Posted 14 August 2010 - 01:31 PM
Posted Image
I've noticed that when you put the PF trains on the seventh speed it seems to tips on corners. Has anybody found a solution to stop it from tipping over ???
P.S I'm not sure if this question has been asked before on this forum.
Edited by The Red Brick, 26 September 2010 - 04:50 PM.
#2 talltim
talltim
    Member: 3099
Posted 14 August 2010 - 01:42 PM
I think the solution is to slow down for corners! The real railway has speed restrictions on curves
#3 Matt Dawson
Matt Dawson
    Member: 7007
    Country: United Kingdom
Posted 14 August 2010 - 04:39 PM
At top speed, the trains will "tip" round curves, due to the fact that curves are extremely tight.
Posted Image
Want to see more photos? See my Flikr!
Posted Image
#4 andythenorth
andythenorth
    Member: 11102
    Country: UK
Posted 14 August 2010 - 05:19 PM
View PostThe Red Brick, on 14 August 2010 - 01:31 PM, said:
Ive noticed that when you put the PF trains on the seventh speed it tips on corners. Has anybody found a solution to stop it from tipping over ???
Put more vehicles behind it, that will slow it down  :tongue:
Making stuff in plastic and pixels: http://ttfoundry.wordpress.com/
Traumatic events in the life of a lego fan: http://www.lugnet.co...traumaticevents
#5 SavaTheAggie
SavaTheAggie
  • Thick-skinned
    Member: 1274
Posted 14 August 2010 - 05:52 PM
It's not a PF specific "problem".  9v trains did this too.
Just manage your speed properly or bank your curves.
--Tony
You only live once, and if you do it right that's all you need.
SRW Locomotive Works
Posted Image
#6 Freddie
Freddie
    Member: 670
    Country: Norway
Posted 14 August 2010 - 07:02 PM
It's a common "problem" - While I can't comment on if the 12V trains did it, all other trains did tip over in corners at full speed. It is an intentional play feature LEGO left in, so kids could have fun with them and incorporating emergency services and such. The exception to this is 4559, which could be sent around corners at full power without tipping over or losing its cargo.
#7 The Yellow Brick
The Yellow Brick
    Member: 11404
    Country: England
Posted 21 August 2010 - 11:14 AM
--Tony
I didn't know that it happend with 9v, I never got a chance to buy any Posted Image
#8 toyboxglobal
toyboxglobal
    Member: 12756
    Country: Australia
Posted 24 August 2010 - 02:44 PM
I agree, it's not a 9V/PF specific problem, rather a question of physics  :tongue:
I guess the solutions would be to:
A) Slow down
B) Add more carriages, but that achieves solution A
C) Add some weight to the bottom of the engine/carriages (lowers the centre of gravity)
D) Bank your curves (as suggested by SavaTheAggie)
E) Speed up and let it fly off the track, it can be rebuilt! That's what is so awesome about LEGO!
Cheers, Jun
www.toyboxglobal.com.au / blog.toyboxglobal.com.au
#9 Goldenmasamune
Goldenmasamune
    Member: 9522
Posted 24 August 2010 - 03:00 PM
its fun to put a bunch of minifigs on a baseplate by that curve, then let the train go crazy. see how many minifigs you can take out.
Reply to this topic
