Using Inika Masks on a Glatorian Head
  • Please log in to reply
4 replies to this topic
#1 Leugi
Leugi
    Member: 8893
Posted 30 June 2010 - 09:04 PM
Well... I always hated the fact that Inika Masks could only be usd with those ugly white/green pieces... Just look at them, they are not transparent or anything... they look bad :(
So I started trying out whatever I could in order to use any other transparent piece for making the masks be more useful and look better... And I got this...
This is all you need, a Glatorian Head, and one of those L shaped pieces (of course you also need an Inika mask):
Posted Image
Next, put the Glatorian Head on the other piece like this:
Posted Image
Now, you must put the mask's back on the back part of the L shaped piece like this:
Posted ImagePosted Image
It is quite tricky, but a way to make it fit better is making it more straight:
Posted Image
And so you will have the following result...
Alternatively, there's another method that seems to work only with Hewkii's mask...
You put the two pieces like this:
Posted Image
You must add the mask like this:
And the result:
So yeah, the main problem with this methods is that the ball joint is way too far, so your mocs might as well be rather humpy, but it does work and look well... I have only tested with Jaller's and Hewkii's masks (because those are the only ones that I have) so if any of you guys manage to do this with other Inika masks, feel free to post your results...
Posted Image
Thanks for reading!
#2 The Crazy One
The Crazy One
    Member: 3823
    Country: England
Posted 30 June 2010 - 09:59 PM
Ooh, great technique. I might use this. I have been experimenting with other masks in the glarorian heads aswell.
Thanks!
#3 Brickthing
Brickthing
  • Mr. Perfect
    Member: 4229
    Country: New Zealand
Posted 01 July 2010 - 04:47 AM
Thanks for sharing this technique!  :classic:
It looks alright from the photos, although the eyes on Hewkii's mask don't look like they fit the eyes on the Glatorian head.
How much are the heads stretched with those pieces?
#4 Aanchir
Aanchir
  • Color Encyclopedia
    Member: 8841
    Country: United States
Posted 01 July 2010 - 12:10 PM
I myself have always preferred to use Toa Mata heads with Inika masks. They fit fairly well if you add some parts to the back to keep them in place. And a range of eye colors are available.
#5 Leugi
Leugi
    Member: 8893
Posted 01 July 2010 - 03:38 PM
Hmn... about 0.3 milimeters or something...
Yeah, the technique used on Hewkii doesn't make it fit exactly with the eyes, so sometimes is better to use the another...
