From TLG:
Hi LEGO Fans,
The LEGO Community Development would like to know which of the already existing elements would be needed most urgently in missing colors. Some optimism presumed the number one of the resulting list could end in a "color change" and might be produced in the future.
To participate - the way is as follows:
Suggestions need to be send by email until the 30.06.2010. These suggestions will be sorted and afterwards published for a voting. The final chart will be send to the LCD Team.
For easier handling the suggestions should be aligned to the description of the BrickLink catalogue: www.bricklink.com/catalogTree.asp?itemType=P
Suggestions only will be accepted in a color which is still in production. So e.g."Fabuland brown" is invalid because production of this color was stoped in 1997.
An overview about the actual colors could be downloaded here: http://www.eurobricks.com/forum/uploads/1263973081/gallery_148_37_26696.jpg
An example:
Part No: 50746
Name: Slope 30 1 x 1 x 2/3
New color: brick-yellow (tan)
Now take your chance to influence the future, but again - follow the instructions as in the example :devil:!
Do you have to point out a specific part and color?
Generally speaking, I would like to see more basic bricks and plates (especially those of larger sizes) made in transparent colors. These kinds of pieces were common at one time in the 80s, but have become rare today.
I requested these:
Part No: 50746
Part No: 2417
Name: Plant Leaves 6 x 5
New color: 21 (bright red)
Part No: 2417
New color: 154 (dark red)
Part No: 2417
New color: 24 (bright yellow)
Part No: 2417
New color: 106 (bright orange)
Part: 973 (Thanks CopMike :sweet: )
New Colour: Transparent light blue
Edited by Roncanator
I second this and would like to add, that clear transparent bricks in general are really cool.
Imagine a transparent minifig! :wub:
The re-introduction of the "big plant leaves" 2417in 'normal' green would be nice. The last set it came in in this color was released 2004!
I requested these:
Part No: 50746
So do I
Part No: 4085
Name: Plate, Modified 1 x 1 with Clip Vertical
Part No: 87620
Name: Brick, Modified Facet 2 x 2
Here are two parts that I could really use in a new color:
Part No: 60608
Name: Window 1 x 2 x 3 Pane with Thick Corner Tabs
New color: Sand Green
Part No: 60594
Name: Window 1 x 4 x 3 no Shutter Tabs
I requested these
Part No: 3829c01
Name: Vehicle, Steering Stand 1 x 2 with Black Steering Wheel
New Color: 28 (Dark Green)
Part No: 60481
Name: Slope 65 2 x 1 x 2
New Color: 24 (Bright Yellow)
Part No: 60481
New Color: 23 (Bright Blue)
Part No: 3005
Name: Brick 1 x 1
New Color: 111 (Transparent Brown)
Part No: 4073
Name: Plate, Round 1 x 1
New Color: 126 (Transparent Bright Bluish-Violet)
The color names and numbers match the TLG color chart linked to at the top of this thread.
Honestly, what part to the instructions below was that hard to understand :hmpf_bad:?:
From TLG:
An example:
Part No: 50746
Part: ?
A quick search of Bricklink reveals the minifig torso to be part number 973!
I guess i'm just being greedy because I need this for a MOC :grin: ;
Item no. : 6218.
Item name : cylinder half. 2x4x4
New Colour : Dark green.
I think we should be honoured that we're given the chance to do this it really shows that TLC really cares about our opinions :cry_happy:
peace out,
GondorToast
Edited by gondortoast
[/font]
The text you quoted does not really address my question. :tongue: I wasn't sure if they were taking multiple part requests and was just thinking that it may make more sense to send in a generic request, instead of a long list of the same part(s) in different colors. From what other people are posting though, such a list seems to be okay.
I think my quote, and the original request from TLG DOES adress your post:
Could be hard to put something as number one on a list by suggesting basic bricks and plates (especially those of larger sizes)?!
To me a pretty clear instruction that they want the part described by using the Bricklink number&name!
Suggestions only will be accepted in a color which is still in production. So e.g."Fabuland brown" is invalid because production of this color was stoped in 1997. An overview about the actual colors could be downloaded here:
Again to me, a pretty clear instruction that they want the specific part described in a specific color as seen in the color overview.
An example:
Part No: 50746
And as the topping on the cake, they even show an example on how they want it to be presented to them!
What was that to be unsure about :hmpf_bad:?!
Calm down, dude. I can't see why you're getting worked up over such a simple question.
None of that says whether you are actually allowed to submit more than one entry. If it is so important to specify a precise part and color, I was thinking it may suggest that they don't want people submitting several, similar entries.
I think this part would be very useful in dark color.
Part No: 57519
Name: Technic Tread Sprocket Wheel Large
New color: Dark Stone Grey
Part: 973
New Colour: Transparent Clear
Part: 133
Name: Minifig, body part
Part: 603
Part: 148
Name: Minifig, Legs Assembly
Part: 973
Part: 133
Part: 603
Part: 148
Smart move!
But the minifig head has got the item number 3626b - and is available in trans clear! :wink:
And where did you get the other numbers from? I can only identify different item numbers... (970c00 instead of 148 for example)default_look.gif
Part: 2593
Name: Wheel Hard Plastic Medium (35mm D. x 31mm)
New Color: Medium Stone Grey
Part: 6118
Name: Light Gray Wheel Hard Plastic Small (22mm D. x 24mm)
Part number: 3004
Name: Brick 1 x 2
New Colour: Dark Brown
Part number: 3010
Name: Brick 1 x 4
Those would come in extemely handy, i think.
I simply want a purple bionicle body... Plus some other bionicle stuff...
Part No: 53547
Name: Bionicle Chest Armor, Toa Inika - Type 2
New color: 124 (Bright Reddish-Violet)
Part No: 53547
New color: 23 (Bright Blue)
Part No: 43558
Name: Bionicle Chest Armor, Toa Nuva
New color: 297 (Pearl Gold)
Part No: 43558
Part No: 64251
Name: Bionicle Fist with Axle Hole
Part No: 53568
Name: Bionicle Foot Piraka Mechanical
Part No: 64251
Part No: 44138
Name: Bionicle Foot Rahkshi
Part No: 53542
Name: Bionicle Foot Toa Inika Clawed
Part No: 53549
Name: Bionicle Foot Toa Inika Elliptical
Part No: 47306
Name: Bionicle Hips / Lower Torso
Part No: 57547
Name: Bionicle Mahri Kongu Torso
Part No: 57547
Part No: 57547
New color: 131 (Silver)
Part No: 61802
Name: Bionicle Mistika Torso / Shoulders Section
Part No: 61802
Part No: 61802
Part No: 53574
Name: Bionicle Piraka Leg Lower Section with Two Ball Joints
Part No: x345
Name: Bionicle Shoulder Armor
New color: 49 (Transparent Neon Green)
Part No: 64292
Name: Bionicle Shin / Ankle Guard
Part No: 64292
Part No: 64292
Part No: 64292
New color: 1 (White)
Part No: 64292
New color: 26 (Black)
Part No: 53548
Name: Bionicle Toa Inika Leg Lower Section
Part No: 53543
Name: Bionicle Toa Inika Thigh Cover
Part No: 53545
Name: Bionicle Toa Inika Upper Torso / Shoulders Section
Part No: 49423
Name: Bionicle Toa Metru Chest Cover
Too good an opportunity to pass up. These are the parts I could think of at the time, feel free to call me boring again...
Part No: 4287
Name: Slope, Inverted 33 3 x 1
New color: transparent
Part No: 3747a
Name: Slope, Inverted 33 3 x 2 without Connections between Studs
Part No: 3665
Name: Slope, Inverted 45 2 x 1
Part No: 3660
Name: Slope, Inverted 45 2 x 2
Part No: 3676
Name: Slope, Inverted 45 2 x 2 Double Convex
Part No: 2341
Name: Slope, Inverted 45 3 x 1 Double
Part No: 6091
Name: Brick, Modified 1 x 2 x 1 1/3 with Curved Top
New color: medium lilac
Part No: 87580
Name: Plate, Modified 2 x 2 with Groove and 1 Stud in Center
New color: white, transparent
Part No: x97
New color: dark green
(this does exist on BrickLink, but was never part of any set and is ridiculously expensive.)
Part No: 62711
Name: Minifig, Headgear Hair Short, Bob Cut
New color: cool yellow / flame yellowish orange
Edited by SilentMode
A few suggestions for a couple pieces that immediately leaped to mind as ones that really needed representation in other colors:
Part No: 30115
New color: 5 brick-yellow (tan)
Part No: 30115
New color: 308 dark brown
Part No: 30115
New color: 138 sand yellow
Part No: 30115
New color: 18 nougat
Part No: 30115
New color: 141 earth green
Part No: 30115
New color: 24 bright yellow
Part No: 48812
Name: Dog / Wolf
Part No: 48812
Name: Dog / Wolf
Part No: 48812
Name: Dog / Wolf
Part No: 48812
Name: Dog / Wolf
New color: 26 black
