MOC: Front wheel drive car
  • Please log in to reply
6 replies to this topic
#1 vladoniki
vladoniki
    Member: 8248
Posted 24 May 2010 - 09:52 AM
Simple car with front wheel drive.
Posted Image
Posted Image
Posted Image
Videos:
Video 1
Video 2
More pictures: My Gallery
Comments and criticism are always welcome!  :classic:
#2 efferman
efferman
    Member: 10499
    Country: Germany
Posted 24 May 2010 - 10:21 AM
two XL for propulsion? is this not a little bit overkill?
#3 vladoniki
vladoniki
    Member: 8248
Posted 24 May 2010 - 10:26 AM
I was just trying to make 2 XL motors for drive. This car does not need 2 of them. I plan to make more chances, the one will be - 1 XL motor to drive it. I will also put a second diff at the back, so the car will have 4x4, part time drive, but first I need to buy a second diff.  :classic:
#4 Sergiu
Sergiu
    Member: 8192
    Country: Romania
Posted 24 May 2010 - 10:40 AM
Interesting MOC, it seems to drive and steer very well.
If you want to make it 4WD you should have the same wheels on all axles, otherwise you will have problems when you drive it. Also I suggest you that you put a central differential in the car, if you do not plan to use it off-road.
I'm sure it'll be great when it's finished.
#5 vladoniki
vladoniki
    Member: 8248
Posted 24 May 2010 - 10:49 AM
Thanks!  :classic: I will put the same diff at the back. I will not add a third diff - full time drive has not good performance for off-road drive.  :classic:
#6 vladoniki
vladoniki
    Member: 8248
Posted 24 May 2010 - 02:59 PM
Here is a new version of the car. Now it is powered by 1 XL motor - horizontally mounted. There is a gimbal to the rear axle, but not yet added a diff. It is stabilized - the battery box is lower mounted.
VIDEO
#7 vladoniki
vladoniki
    Member: 8248
Posted 07 June 2010 - 08:57 PM
I have made more changes. Now the car is 4x4 part time and it has a better rear suspension.
Posted Image
More pictures - click here
Video - click here
It uses 2 XL motors - 1 for steering, the other for driving.
