SR 3D Builder 0.5.1.3 released
  • Please log in to reply
8 replies to this topic
#1 xSergio74
xSergio74
    Member: 6441
    Country: Chivasso
Posted 11 May 2010 - 04:23 PM
Hi everybody,
It's publish time !!!!
Here is my new release of SR 3D Builder 0.5.1.3 with astonishing new functionality and interface!!
Am I exaggerating?
Well, let me know!
Application available for free as always (even if a small contribution is welcome  :D ) from
http://staff.polito.it/sergio.reano
Here is a video introducing new functionality:
Sergio
#2 Superkalle
Superkalle
    Member: 4755
    Country: Sweden
Posted 11 May 2010 - 04:39 PM
Hi Sergio
Great news. I'll have to try it out.
Eurobricks Digital Design Forum - for all your LDD and Ldraw cravings
#3 Calabar
Calabar
    Member: 10232
    Country: Italy
Posted 11 May 2010 - 05:35 PM
Great news!
The only reason I'm not using this software now is that I don't want to install the .NET fremework on XP.
Wen I'll upgrade to Seven I think I'll do a massive use of it.
"Official LEGO Sets made in LDD" topic: Read guidelines before posting!
#4 NecroViolator
NecroViolator
    Member: 9892
Posted 11 May 2010 - 06:01 PM
Looks awesome ... :)...
Might give it a go...
Some Ideas :
The entire screen should be like Serious Editor/Unreal editor so you can see from all directions...
The huge problem with Lego Building is you only see from one camera and LDD would "glue" a piece over or under when you dont want it to...
Great work !!!
Thanks !!!
#5 Zblj
Zblj
    Member: 7054
    Country: Slovenia
Posted 11 May 2010 - 06:31 PM
Downloading it now. Is there any way to open an lxf file, so i cant try out the mechanics?
#6 xSergio74
xSergio74
    Member: 6441
    Country: Chivasso
Posted 11 May 2010 - 08:12 PM
Hi,
you can try to export your model in .ldr file format from LDD and then load it from SR3DBuilder, but I cannot grant the result for 2 reasons:
- Part definition in LDD is quite different from the one I'm using (compatible with lDraw/MLCad standard)
- My application uses a high precise and automated part positioning. If model are not correctly build then animations will not be detected
Anyway you can try
Sergio
Some Ideas :
Great work !!!
Thanks !!!
Hi,
after a bit of experience you will find the interface I used by far better than any other you try before. I recommend reading manual to deeply understand its functionality and flexibility
Sergio
#7 Milan
Milan
    Member: 6465
    Country: Serbia
Posted 11 May 2010 - 08:27 PM
Thanks for your work, and keep up!
Posted Image   Posted Image    Posted Image   Posted Image Posted Image    Posted Image
Website  Facebook  YouTube   Flickr    Brickshelf Mocpages
#8 NecroViolator
NecroViolator
    Member: 9892
Posted 13 May 2010 - 09:40 AM
View PostxSergio74, on May 11 2010, 09:12 PM, said:
Hi,
Sergio
OK, thanks...
Im guessing you have used those other Map Editors Ive mentioned so you can get the best from both ??? :)...
Gonna give it a go :)...
#9 xSergio74
xSergio74
    Member: 6441
    Country: Chivasso
Posted 19 May 2010 - 07:58 PM
Hi,
on the site there is a new version with just some small fixes to remove annoying interference between the 3arrowed axles, now called Displacement Caddy (D-Caddy) and other interface functionality.
Also added a quick color selection: read history tab on website for details and news.
If anyone has a more adequate name for that object (the 3 axle with the arrows around and the center) please let me know...
Same website...
Byes
Sergio
