LDD and Rotating...
  • Please log in to reply
18 replies to this topic
#1 Follows Closely
Follows Closely
    Member: 7999
Posted 15 January 2010 - 05:48 AM
I have a MOC that I am attempting to design in LDD.  I am having a hard time rotating the large portions.  Here is my First floor:
Posted Image
see the remaining two rotation points?
Posted Image
I rotated two joints, but I can not rotate the remaining two joints.  Is this possible in LDD?
Here is the CornerV3.lxf if anyone is interested.
P.S. Guess ho much this cost? (we need to have polls turned on!)
Posted ImagePosted ImagePosted ImagePosted Image
#2 Peppermint_M
Peppermint_M
  • Spam Hunter
    Member: 4757
    Country: Wales.
Posted 15 January 2010 - 08:48 AM
Use the rotate tool?  If that hasn't worked then there is issue with its movement from the building. I found the new rotate tool very good and easy to use. However if I build a section wrong it won't rotate. The problem is you aren't holding the MOC so you don't know where the issue preventing rotation is.
If Anime has taught me anything, we're gonna need a gunsword
Its the music that saves you when you're not so sure you'll survive
New Member? Read This | Questions? Need Help? Ask Here
Site Guidelines | Eurobricks FAQ | Visual User Guide
#3 xSergio74
xSergio74
    Member: 6441
    Country: Chivasso
Posted 15 January 2010 - 08:51 AM
Hi,
the problem is that often the rotation hinge in LDD is chosen from the program and not from you.
It's better to migrate your work to a more appropriate Lego application.
A good one could be SR 3D Builder. It has a lDraw/MLCad compatible part library (near 5000 parts) available in all colors.
You may need to read the manual to get clue with it, but it is really powerful
Website: http://staff.polito.it/sergio.reano
Sergio
(I'm the author of the program)
#4 Follows Closely
Follows Closely
    Member: 7999
Posted 15 January 2010 - 02:03 PM
View PostxSergio74, on Jan 15 2010, 03:51 AM, said:
Hi,
Sergio
The first rotate went just fine.  It seams that you can not rotate a section that has a rotated angle already.  About the colors, yeah, alll the light gray in my model are blocks that ldd did not have the right color for.  Does your program have any integration with bricklink?
#5 prateek
prateek
  • Study hard!
    Member: 426
    Country: Canada
Posted 15 January 2010 - 09:44 PM
LDD is messed up in the way that the hinge tool only works only on some parts. I have this problem all the time, and usuallly, I just take it apart, rotate the hinges on their own, and then attach the parts back.
#6 Follows Closely
Follows Closely
    Member: 7999
Posted 16 January 2010 - 01:13 AM
How do you rotate an entire object say 15%?
#7 TheAllSeeyingGuy
TheAllSeeyingGuy
    Member: 8307
Posted 16 January 2010 - 08:22 PM
View PostxSergio74, on Jan 15 2010, 09:51 AM, said:
Hi,
Sergio
My virus scanner detected a trojan when i downloaded you're program (that was a week or 3 ago).
#8 prateek
prateek
  • Study hard!
    Member: 426
    Country: Canada
Posted 17 January 2010 - 01:13 AM
In the new LDD, the rotation tool is very precise, so I think you'll just have to guesstimate how much 15% is.
#9 Superkalle
Superkalle
    Member: 4755
    Country: Sweden
Posted 17 January 2010 - 11:22 PM
I opened your model and had a look at it. The first things I noticed was that the two wall segment to left and right of the door had bricks that were disconnected. Use the "Connected Selection Tool" and you will see what I mean. Secondly, I noticed there were no hinges in the model. So I added a few of these: http://www.bricklink...m.asp?P=2429c01 in each corner. AFter that, it was no problem to rotate the walls in any way. See attached file. Please let me know how it works out.
#10 Follows Closely
Follows Closely
    Member: 7999
Posted 18 January 2010 - 01:20 PM
Many thanks.  It was the disconnectedness that was causing the problem.
Edited by Follows Closely, 18 January 2010 - 01:30 PM.
#11 xSergio74
xSergio74
    Member: 6441
    Country: Chivasso
Posted 21 January 2010 - 09:04 AM
Hi,
that is not a troyan.
I simply put a hidden reference to an external link to let a Perl Script to count and make statistics around the visitors I get on my site
The hidden link refers to a ITLug stored documents that receive the hit and increments the counter.
That's all, believe it or not
Sergio
Hi,
no integration with bricklink at the moment, maybe it the future...
Sergio
#12 Follows Closely
Follows Closely
    Member: 7999
Posted 21 January 2010 - 05:53 PM
Sergio
The ability to generate a wanted list on bricklink would be very nice.
#13 Superkalle
Superkalle
    Member: 4755
    Country: Sweden
Posted 22 January 2010 - 04:03 PM
You can try WantedBricks - it will allow you to create a Bill-of-Material, as well as upload to BrickLink.
http://www.nolberger...cks/Default.htm
#14 Follows Closely
Follows Closely
    Member: 7999
Posted 22 January 2010 - 04:28 PM
Nice find.  Thanks.
$62 on bricklink, $138 at shop at home.
Edited by Follows Closely, 22 January 2010 - 04:30 PM.
#15 Superkalle
Superkalle
    Member: 4755
    Country: Sweden
Posted 23 January 2010 - 10:34 PM
View PostFollows Closely, on Jan 22 2010, 05:28 PM, said:
Nice find.  Thanks.
No prob. Glad to be of help  :classic:
#16 gotoAndLego
gotoAndLego
    Member: 8984
    Country: USA
Posted 15 February 2010 - 03:54 PM
This is a LDD question as well.
How do you just use the turntable base without the studded part? Since they always come as separate parts in the kits, like the hinges do, shouldn't you be able to do this?
Edited by gotoAndLego, 15 February 2010 - 03:55 PM.
Please support my Lego Cuusoo projects:
Posted Image Posted Image Posted Image Posted Image
FLICKr
#17 Superkalle
Superkalle
    Member: 4755
    Country: Sweden
Posted 15 February 2010 - 05:45 PM
The simple answer is (like you've discovered) that you can't use them separated in LDD. To understand which pieces can, and which cannot be used separately, we need to have a look at some Lego system logic. We have the following cases:
1) Parts that are joined from factory and cannot be dis-joined (example: steering wheel to base)
Posted Image
2) Parts that are joined from factory and can be dis-joined (example: lever)
Posted Image
3) Parts that are not joined from factory, but are not meant to be separated once connected (example: turntable)
Posted Image
All of the above type elements cannot be used as separate pieces in LDD, and the reason is that LDD quite strictly follows how bricks can handled by children (the basic norm at Lego), and thus how elements would be used in official Lego sets. I know that the turntable base was used in 10189 Taj Mahal, and therefore could be seen as "legal", but I guess that's the exception that confirms the rule.
#18 gotoAndLego
gotoAndLego
    Member: 8984
    Country: USA
Posted 15 February 2010 - 07:25 PM
Posted Image
The base is also used alone on the V19 Torrent's wings, and I'm sure there are other models. I guess its just a limitation in LDD and not something I overlooked.
Edited by gotoAndLego, 15 February 2010 - 07:30 PM.
FLICKr
#19 Superkalle
Superkalle
    Member: 4755
    Country: Sweden
Posted 15 February 2010 - 08:40 PM
Yepp, in that sence it's a limitation in LDD.
