Problem with battle droids?
29 replies to this topic
#1 Trudop561
Trudop561
    Member: 2010
Posted 16 August 2009 - 11:45 PM
Posted Image
Hello, Star Wars fans
You may already have encountered problems with battle droids joints and clips, especially for the arms and the legs and some of you are professionnal in taking care of your minifigs. I would know what is the best solution to store these droids : let them in their sets or display them on a large baseplate. I am wondering about this because, when I am not playing with my sets, I put them back on their shelf and they can stay there for a few weeks and I do not know if, with the time, the droids can break or have problems during this time.
I know it may occur with old droids from 2000 but with the new ones (2007, 2008...) ?
You may also share your personnal stories  :classic:
You can close the topic when an answer will have been provided.
Thanks
#2 Rocky
Rocky
    Member: 7016
Posted 17 August 2009 - 12:24 AM
I don't move any of my lego battle droid hinges at all myself. My droids from the 2000 MTT and ATT are still like new. Another thing that wears them out is holding blasters (guns). It stretches out the hand over time.
To store them I would dismember them into ziplock bags. Even when a droid isn't being played with there is presure on it's limbs.
You shouldn't have any troubles though. Lego was meant to be played with and shouldn't break unless under quite a bit of stress or heavy use. Putting them on a shelf for weeks will not wear them out.
#3 Corvus
Corvus
  • ¡ʎpuɐɯ ɹǝʌǝɹoɟ
    Member: 1483
    Country: USA
Posted 17 August 2009 - 03:23 AM
Whatever you do: Don't put them in water. My family made a LEGO brick cake and stuck a lot of droids on top. When I soaked them in water to get the cake off of them, most of the joints on my Super battle droids failed. As a result, I have very few SBDs. :sceptic:
Meh, it was a good cake anyway.
As far as I can tell, non of my normal battle droids are experiencing any problems.
True happiness: looking inside the box to see a perfectly flat instruction manual.
Posted Image
#4 Millacol88
Millacol88
  • Pokey
    Member: 2723
    Country: Canada
Posted 17 August 2009 - 03:44 AM
There are definitely problems with BD joints snapping under what would generally be considered normal use. I know after getting the 7660, I left it on display for around a year, then needed to take it apart for a MOC. As soon as I went to detach one of the BD arm held-on wings of the vulture droid, I snapped one of the joints. :hmpf_bad: You seem younger, so you probably like keeping your Minifigures together. But really, the only way to prevent them from snapping is to not leave them attached for long periods of time.  :sceptic:
#5 prateek
prateek
  • Study hard!
    Member: 426
    Country: Canada
Posted 17 August 2009 - 04:14 AM
As Millacol88 said, BD droids arms snap really easily. I have 8 BD arms and out that 8, 4 have snapped. That's a whole 50% of all my BD arms! Now they are almost useless. :hmpf_bad:
#6 Destroydacre
Destroydacre
    Member: 6646
    Country: USA
Posted 17 August 2009 - 04:41 AM
Hmm, this is an interesting topic. I've always displayed my battle droids and my earliest onces (Naboo Swamp, Original MTT, AAT, etc) got a decent amount of use out of them, but I've never had any problems with the droids themselves or with any of the joints breaking. I'll definitely make sure to treat them more carefully now though after reading this thread.
#7 gogglev
gogglev
    Member: 6045
Posted 17 August 2009 - 05:42 AM
I think the problem with the Battle Droids is primarily with the older droids. All my older battle droids have either loose joints or have had arms broken at the hinges. None of my droids from the past few years have had this problem and they seem to be made of a better quality plastic or something.
This usually works with softer plastics so i'm not sure if it will work with the droid arms, but if you run the arm under hot water to soften the plastic a bit, you can try to compress the  joints to make them tighter, though don't apply too much force. You could also try coating the pin on the droid body with a thin layer of super glue to create some friction for the arms.
Edited by gogglev, 17 August 2009 - 05:43 AM.
#8 Trudop561
Trudop561
    Member: 2010
Posted 17 August 2009 - 07:17 PM
Thank you, everyone, for your answers and advises. I will take note of what you said and do what is necessary to preserve my minifigures.
#9 Jammiedodger
Jammiedodger
  • Halfway through Englishman
    Member: 3865
    Country: England
Posted 17 August 2009 - 07:26 PM
So should I dismantle my droids standing on a 32x16 baseplate? :oh: They have been like that for a month or so now. :look:
Edited by Jammiedodger714, 17 August 2009 - 07:26 PM.
#10 The Who
The Who
  • No more boogers
    Member: 2808
    Country: United States
Posted 17 August 2009 - 07:32 PM
After years of display, mine are all fine.
I only ever broke one SBD, and it was brand new, and very brittle.
"When informed of the waiting period on guns at walmart; it is not infact witty to reply asking where the chainsaws are. Police will be notified."
Like free third person shooters? Online? You should join me on Battlefield Heroes, make sure you use this link.
Battlefield Heroes Link
#11 Holy Diver
Holy Diver
    Member: 3285
Posted 17 August 2009 - 07:37 PM
I've had battle droids since 1999 that have suffered heavy use and abuse and they haven't broken on me yet.  But, if one does break, I have a hundred others to replace it.
The super battle droids on the other hand are breaking left and right.  A skillful application of model glue can fix it, but it is still anoying.
#12 fenris
fenris
  • Photo This!
    Member: 6569
    Country: Austria
Posted 19 August 2009 - 11:37 AM
i got mine all "used" and they are still fine... maybe there's a difference with different lots... i tried the warm water - refitting trick and it worked well with the ones that where a little "hang my head"... thanks for the tip.
#13 HumanPackMule
HumanPackMule
    Member: 6241
    Country: U.S.A
Posted 19 August 2009 - 12:26 PM
Tell me about it. The arms of my SBD's are in very small fragments. I'd have to say this is a worse problem than the Bionicle joint breaks.
For an optimist, the glass is half full. To the pessimist, it is half empty. To the engineer, it is twice as big as it needs to be.
#14 DarkFader
DarkFader
    Member: 7089
Posted 19 August 2009 - 02:46 PM
I've had no problems with the battle droids I own except for one that broke: a super battle droid. The leg clip just snapped off so it proved that they are some of the most fragile minifigs; it's quite odd that the normal LEGO battle droids are sturdier than the SBD's when it technically should be the other way around.
#15 Skipper 24
Skipper 24
  • I live in Engalnd
    Member: 1851
    Country: England
Posted 19 August 2009 - 06:01 PM
Why is that? I think SBD's are made from a slightly different type of plastic, a harder and less flexible one at that. I think this is why people are having there legs snap.
I personally have only had normal battledroid arms snap. All of which have been replaced by the spares that come with lego sets or ones that come from LEGO customer service. If you have any snapped arms, legs etc. I recommend talking to customer service via email or phone. They usually understand and will send you a replacement free of charge :thumbup:.
Posted Image <-- Thanks Hound Knight
Flickr Brickshelf
#16 DarkFader
DarkFader
    Member: 7089
Posted 19 August 2009 - 06:50 PM
Yeah, I think you're right; the part about "the other way around" was just something I was thinking when reading the rest of the thread. Accidents do happen, though, so both droid types might snap at some joints even though the normal battle droid minifigs haven't broken for me personally.
But I do think that the SBD's should get an upgrade by TLC so they don't break so easily; perhaps a lighter type of plastic oughta do the trick?
#17 Big Cam
Big Cam
  • No good dead ever goes unpunished.
    Member: 5701
    Country: USA
Posted 20 August 2009 - 02:30 PM
I store mine dissasembled so I can't say I have this problem.
#18 AFOL12v
AFOL12v
    Member: 921
    Country: The Netherlands
Posted 20 August 2009 - 03:28 PM
I have 200+ droids, but only arms have broken and maybe 1 or 2 legs and head. But I admit, it's very fragile and should handle with care.
Posted Image
Only the sandred ones are very expensive to replace..........
#19 Commander_Rob
Commander_Rob
    Member: 3863
    Country: Germany
Posted 20 August 2009 - 03:42 PM
Sandred droids, my god. Of the two I got, three arms have broken.
With other droids I have also had the problems described above: occasionally an arm breaks, the neck and leg joints of older droids (original MTT, Naboo fighter) are a bit worn out  and my original bluish Super Battledroids have broken three of their total of six joints and some of the other SBDs have snapped legs.
I have come to fix these with very thin wire, that works quite well.
Edited by Commander_Rob, 20 August 2009 - 03:43 PM.
Just call me Rob.
#20 The Rancor
The Rancor
    Member: 3035
    Country: UK
Posted 20 August 2009 - 03:48 PM
No, it's never happened with any droids I've bought ever since the droids Episode 3 battlepack in 2007.
However, some of my old droids (such as original Episode I set droids) do have problems with too big hinges.
It doesn't matter though, because I've got the newest MTT so I have loads of droids!  :grin:
AKA shadowtrooper1 on Brickshelf
Part-time lurking Count
#21 Rain Jake
Rain Jake
    Member: 7104
    Country: U.S.A
Posted 20 August 2009 - 04:29 PM
I have a SBD that has a broken hip joint, he wont stand up, so I call him Wobbles :tongue:
Have A Nice Day!
#22 Trudop561
Trudop561
    Member: 2010
Posted 20 August 2009 - 04:43 PM
It already happened for a few of my SBDs but almost never with simple droids. However, sometimes, the legs are not well fixed to the body and turn very easily  :hmpf_bad: . I just do an exchange of legs between two droids and the problem is solved. And, every month, I'm doing an "inspection" of each of them to check if there are broken pieces  :grin: . Oh well.
#23 The Who
The Who
  • No more boogers
    Member: 2808
Posted 20 August 2009 - 06:33 PM
I think the best solution, if you want them to stay built on display, is just don't play with them. Simple as that.
I know Lego is made for the purpose of playing with, but it is the best way to go, I think.
What I do is buy the set (with droids, of course), build it, put it on display, and leave it there. You can't constantly take the droids apart and put them back together.
And if you do anyway, always 'slide' the regular droid arms on, don't snap them on.
#24 simonjedi
simonjedi
  • PT Jedi are the BEST!
    Member: 1965
    Country: UK
Posted 20 August 2009 - 08:28 PM
I've got battle droids from the original 1999 releases that apart from the obvious wear and tear are still fine.
I've not yet encountered the SBD problems either.
Posted Image
| 7674 V19 Torrent Starfighter Review |
[*] Dr. Ben Elegnem, head of medical staff in INFECTED (Killed Night 2) (Not Infected)
[*]Jimmy Palmer (Gas Station Attendant) in Prohibition Mafia (Scum)
#25 Spyder
Spyder
  • Minifig Identikit
    Member: 5419
    Country: USA
Posted 25 August 2009 - 07:35 PM
Some of my B1 battle droids have loose joints, but I don't think I've had any of them break. Plus they are mostly from 1999, and have gone through lots of play. I haven't had any problems with any SBDs, but maybe that's because I only have one, I built him, put him on display with the set, and now I can't find him. :hmpf_bad:
"You either die a hero, or you live long enough to see yourself become the villain." -Harvey Dent, The Dark Knight
Long Live The Nizam!
Quoting Charlieboy:
Quote
Be carefull playing lego in the nude,those small parts can get everywhere!!!
Reply to this topic
