LEGO Technic Hydraulic Set
#1
Posted 02 March 2008 - 12:35 PM
I haven't got access to my old LEGO catalogues so I can't give you a set number but I swear there was a Technic set that had hydraulics instead of pneumatics! Early 2000's I think. Possibly a green/black colour combination.
#2
Posted 02 March 2008 - 01:25 PM
Full details on the Siegfried About Me page!
#3
Posted 02 March 2008 - 01:48 PM
Hydraulic Set
#4
Posted 02 March 2008 - 06:07 PM
It's not the Barcode Truck you're thinking off? That was green and black, and came out around the millenium. That was all electronic and mechanical, though.
#5
Posted 02 March 2008 - 06:32 PM
Edited by CP5670, 02 March 2008 - 06:34 PM.
#6
Posted 02 March 2008 - 09:04 PM
Now I know the year, i'll look up the description. It wouldn't have stayed in my mind for no reason!
EDIT ^^^ post above: yep, that's exactly right.
Thanks everyone
Edited by chris_austin, 02 March 2008 - 09:06 PM.
#7
Posted 03 March 2008 - 03:45 AM
As you have discovered by now, they called the pneumatic dampers "hydraulics" at first. I never figured out why they did this. The pneumatic actuators at least function like hydraulics even if they use air for a fluid instead of oil (and are compressible). But the dampers have nothing in common with hydraulics whatsoever. I guess they just couldn't think of a good marketing term for them, or perhaps it was just a poor translation into English.
As someone who works with aircraft hydraulics for a living, I remember being pretty excited when I first saw this in the catalogs, and then pretty disappointed when I found out what they actually meant. As if that wasn't bad enough, the first released dampers were very poor and broke after only a few cycles, but at least LEGO replaced them with an improved design for free.
Real hydraulic fluid is pretty caustic and certainly messy, so I doubt LEGO will ever go that route.
Eric
#8
Posted 03 March 2008 - 04:11 AM
#9
#10
Posted 21 October 2008 - 04:58 PM
Kamil, on Oct 20 2008, 11:16 PM, said:
Yes, you can make a damper work with either hydraulics or pneumatics, but they work somewhat differently. In both cases, the output of the fluid (air or oil) is metered through an orifice. The smaller the orifice, the slower the fluid can escape, which controls the rate of the damper. Air is compressible so changes volume considerably under load. For this reason, only relatively small loads can be supported without a large displacement. Hydraulic oil is (mostly) incompressible so it can react very large loads immediately. This is what is used in an automobile shock absorber, or even one for a radio control car.
The term "hydraulic" refers to using incompressible oil, so it really cannot apply to the Lego dampers. I think they just wanted a term to make sure people knew it was not the same old pneumatic system.
#11
Posted 21 October 2008 - 05:27 PM
Now that you feel it, you don't
You've gone off the rails
Reply to this topic
