8273 Technic Off Road Truck Review
  • Please log in to reply
14 replies to this topic
#1 Lasse D
Lasse D
  • Pink Poodle
    Member: 1144
    Country: Denmark
Posted 25 August 2007 - 08:27 PM
The box
The truck comes in a big square faced box showing the main model on the front and secondary model on the other side:
Posted Image
Posted Image
The build
The model has polybags numbered 1 to 4 which makes the build very easy. It took me 2 hours to build with a sedated pace.
There are 4 instructions manuals, two for each model
Posted Image
The bags with 1 lets you build most of the frame
Posted Image
After 2 you get the rest of the frame and the bed
Posted Image
3 Gives you the crane and fuel tanks, while the cab is made using the bags with 4.
Posted Image
Posted Image
Posted Image
Functionality
Being a medium sized Technic model, I expected a lot of functionality. This model gives you:
- Working steering with the knob on the tilting cab. The ideal solution which beats the rear mounted steering wheel of the fire truck 8289.
- Rear suspension. This is done using a bogie like on many other LEGO models. I expected something more special when reading the description of this "off road truck"
- Winch. Extremely simple, but uses a technic pin with friction for... friction which is compact and nice.
- Tipping cab. And what is beneath the cab in a truck? Nothing! Last time I saw a tipping cab without an engine beneath was the truck from 8062 in 1994. It had a mechanism for tilting the cab and the excuse of being a secondary model.
- rotating crane with 2 joints. The upper joint is operated from the top of the crane which is a solution that makes the crane less fun to operate. I think all the functions should be controled remotely. If that requires pneumatic, then so be it.
- Tipping bed. The bed tips by turning a knob on the side. It works well and you can tip the side panels up if needed.
Posted Image Posted Image
Design
The only things I really love in this model are the fuel tanks. They look very good. The rest of the truck is pretty average. The interior is pretty much a copy of 8289, the bed is placed very high, but the proportions are good.
The stickers are all on single pieces and are numbered to make the build even easier.
Conclusion
- Price: 6/10. Priced nearly identical to the Crawler Crane. Cheaper than 8289, but no real bargain.
- Functionality: 4/10. I miss an enigine with working pistons and the steering on top of the crane drags the score down.
- Design 6/10. It doesn't look bad, but not great either. There isn't much off-roading in the rear bogie and many of the ideas have been seen before.
- Secondary model: 4/10. It is pretty much like the main model, but uses the crane base to connect the two halfs in the middle. An interesting suspension, but resembles the primary too much for my likings.
- Modifiability: 4/10. It would probably not be hard to motorize it, make a better suspension or modify the crane to use pneumatic. Modifications like that would however almost make a new truck and then I would rather just play with the 8868 Airtech claw rig or 8828 crawler crane.
Overall it is pretty much like 8289 regarding both functionality and design. It has slightly better functionality, but is really only average which leads me to the conclusion that this set is average in every way - There is nothing to set it apart, but nothing really bad either.
- Final score 5/10. Better than 8289, but for the price I will recommend a crawler crane instead.
(BrickShelf gallery)
Posted Image Posted Image Posted Image
#2 simonwillems
simonwillems
  • Technic Campaigner
    Member: 1116
    Country: The Netherlands
Posted 25 August 2007 - 08:46 PM
Thanks for the review of this model.
It looks nice, quite tall though. The second model looks even better in my opinion being lower than the original model. The color scheme looks pretty and I like that it has lots of lights making it a robust looking Off Roader.
I wouldn't buy this one but it's nice to see it's around for people who will.
#3 Asuka
Asuka
  • Pictural Poet
    Member: 816
    Country: Schnitzelland
Posted 25 August 2007 - 08:56 PM
A very nice review of a nice but somehow mediocre set.  *y*
What I like most is just what type of truck that is,  a very neat and playable model.
Pneumatics for remote controlled  features on, yep!  *sweet*
#4 Ickelpete
Ickelpete
    Member: 539
    Country: England
Posted 25 August 2007 - 11:18 PM
Thanks for the great review Lasse D *y*
I am a big technic fan but this set is not on my want list the early pictures were a little disappointing
and you have not said anything to change my mind.
Technic sets should have a lot of functionality and when sets are designed to fit into a price bracket this is often lost.
I would be interested to know what you think of the alternative model
#5 Sinner
Sinner
  • Mike's Magical Elf
    Member: 1554
    Country: Australia
Posted 26 August 2007 - 02:23 AM
Thanks very much for the review. You have convinced me that I only want this set on sale. It seems to be an odd year for Technic; most sets seem average except the Bulldozer. The crawler crane is on it's way to me now; it is still available for Australia and that is probably why we can't buy this set yet. The biggest reason for me to buy this set is for the wheels. Very disapointing the complete lack of a drivetrain.  :'-(
(Any chance of passing on the instuction book codes?)
Posted Image Posted Image Posted Image Posted Image
Full details on the Siegfried About Me page!
#6 mutex
mutex
    Member: 979
    Country: Belgium
Posted 26 August 2007 - 05:22 AM
Thanks for the review.
Your opinion confirmed my initial thoughts : pretty bland and uninspired set.
Let's not buy this one and save money for the wonderful Power function bulldozer  :-P  *y*
Edited by mutex, 26 August 2007 - 05:23 AM.
#7 julencin2000
julencin2000
    Member: 1835
    Country: Spain
Posted 26 August 2007 - 05:25 PM
Thanks for pics & review  *y*
#8 Lasse D
Lasse D
  • Pink Poodle
    Member: 1144
    Country: Denmark
Posted 26 August 2007 - 05:42 PM
I have taken some pictures of the secondary model now. It is a pretty basic tow truck with a lifting mechanism for the crane and steering mechanism as its only functionality. It is however a little more entertaining to play with than the primary model because of the way the two halves are connected. I suggest building this model if you want to play with it.
Posted Image
Posted Image
Posted Image
(I have changed the crane slightly using an extra pin in the end so that I didn't have to cut the line)
A thing I forgot in the review is that the crane of the primary model isn't good at picking up the pallet. I still haven't found a way to make it work because of the way the fork is suspended.
#9 Christian
Christian
  • *Still* The Tallest AFOL on the planet!
    Member: 325
    Country: Denmark
Posted 26 August 2007 - 07:04 PM
Thanks for another nice review!
I like the overall shape of the truck very much. Im just wondering where you bought it from and what the price was? I've been looking for it for some time now, but it isn't available at my local Tru, where I work.
Posted Image
Go here and find out what the academy is all about!
My Brickshelf gallery
My Flickr
#10 Lasse D
Lasse D
  • Pink Poodle
    Member: 1144
    Country: Denmark
Posted 26 August 2007 - 07:32 PM
You have to buy the set in a foreign country if you want it right now. It is one of the September releases so the Danish shops should begin to get it after September 3rd.
I can't remember the MSRP for this set in Denmark, but I think it is about 470kr. (€63)
Do you happen to work at Toys'R'Us in Tilst? If that's the case, I might have met you in my last raid (-40% on everything because of Bilka next door and the price guarantee *pirate* )
#11 Christian
Christian
    Member: 325
    Country: Denmark
Posted 26 August 2007 - 07:48 PM
ok, thanks.
No, I work in the Tru in Næstved, and I mostly work in the part of the store which has the lego department :-P . So i walk around tons of Lego every day. I even get to open op all of the boxes form the warehouse. its such a nice feeling ;-) .
I used the price guarantee from Bilka, too, and used my extra 10% employee discount. actually the discount was like 20% instead, because it was taken from the total before the 40%. So I saved a total of 50% :-P .
Posted Image
My Flickr
#12 5150 Lego
5150 Lego
  • Has a ball of string and isn't afraid to use it
    Member: 586
    Country: United States
Posted 27 August 2007 - 03:43 AM
Nice review! Do you have any pics of the suspention flex? Shame there's no engine.
Calm down... HAVE SOME DIP!
If at first you don't succeed,........ Then skydiving is not for you!
Check it out! www.emergencybricks.com
#13 Lasse D
Lasse D
  • Pink Poodle
    Member: 1144
    Country: Denmark
Posted 27 August 2007 - 12:28 PM
Wow. That's even smarter! Lucky you  X-O
>5150 LEGO
I don't have a picture that shows that, but I have the exact same system on this old trailer.
It is a bogie with a single axle of connection in the middle so that it can tilt a bit back and forth. Pretty much the most basic way of doing it next to having no suspension at all.
#14 Sinner
Sinner
    Member: 1554
    Country: Australia
Posted 28 August 2007 - 04:24 AM
Our pal Rosco has added this set to his index.... *sweet*
EDIT: I just finished looking through the instructions.
Indeed, it is a novel idea. I thought they used the turntable when you said it. It would be funny to see a car really made that way.
#15 dunamis
dunamis
  • It's no good captain i canny reach!!!
    Member: 226
Posted 28 August 2007 - 07:47 AM
Nice review, well done.
I almost picked this up at Toys R Us today.  It was $59.95.  I stopped because I wondered if it was one of the sets that TRU jacks the price up.  Sure enough, I was right.  It is only $49.95 on the LEGO site.
It appears that it looks better on the box than it really is.
Anyway, thanks again for the review.
So much LEGO, so little time...
