Sign in to follow this
Followers 0
piterx
high & low ratio gearbox
11 posts in this topic
hi guys!
im away from my legos for some days but i have something i didn't show you :)
this is my idea for a high and low ratio gearbox for a 4x4 that im doing....
i think it's nice because it's only 3 studs wide and it's 5 studs from the input to the output
it also hosts a free axle for an eventual second function such as a steering system
:sweet: hope you like it and it's gonna be useful
Edited by piterx
Share this post
Link to post
Share on other sites
"im away from my legos for some days" This is just not good enuf!~! :P
I guess I will have to build it to see! :D
Great job on its compactness
Edit: After following the path of motion using my "imagination" :P I have a feeling that the torque will separate the 8t from the 24t for the low gear. Have you tested this? Could be wrong tho. :D
Edited by Doc_Brown
Share this post
Link to post
yea it could be but it has to be braced someway to the chassis so it doesn't dismount :P
Share this post
Link to post
hmmm not yet and i can't even test anything for now...
anyway i will connect the gear selector to the rear differential so when the low ratio is selected the differential gets locked for a better climbing
Share this post
Link to post
If you used a driving ring extension piece, you could save some gears, the second layer of axles and gears would be gone, and it would be only one stud longer. Your solution is too complex for such a simple thing.
Share this post
Link to post
Was the gearbox (transpher case 1) in this pic what you was thinking of?
Edited by allanp
Share this post
Link to post
Exactly. I am making instructions like crazy so I didn't bother looking it up.
Share this post
Link to post
How it can be 3 stud wide with old 4 stud differantial? :classic:
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
