Sign in to follow this
Followers 0
Rail Co
[Help Needed] 12v newbie with burnt out motor
4 posts in this topic
Hello, I am reaching out to all 12v train users. I recently purchased and received a 12v train (the 7725). Unfortunately the motor is dead, I put it on the track after building the whole model and setting all the track up to find it not moving. At first I thought maybe if it hadn't run in awhile it would need a little help. That didn't work so I tried it by just connecting a wire to the motor itself and gently moved the wheels. The motor started to produce a light smoke so I immediately shut the power off and haven't tried anything since. I did see some life though at one point, it did move about 1/16 of a turn at best and I could hear it trying to move. If the seller is cooperative hopefully I can work something out with him. If not I was hoping many people on this forum could lead me in the right direction.
Here is what I know about the motor: It looks to have been opened before. It is the version with the separate bogie pin. From what I can see there is some hair spun around the axles.
I am wondering if I need to completely give up on the motor or if there is a way to fix or replace just the motor inside. I am really lost and would love any help that someone could give me. I looked for awhile but I haven't found a post about someone having the same problem as me. Even if someone has a broken lego casing for the motor but there electrics still work I could be interested in that as well.
Thanks,
-RailCo
Share this post
Link to post
Share on other sites
After fiddling with it for about an hour. I was able to remove a gob of hair (nasty :sick:) and realized that one of the axles was stuck and was able to free it. not that I have done this it sometimes moves slowly with a clicking noise and then will stop I am assuming something is rubbing up against the axle or gears to cause friction but I'm not sure.
-RailCo
Share this post
Link to post
I know that Patrick from BeLUG is good at repairing 12V motor, maybe send him a message?
Share this post
Link to post
Hallo Rail co
I have answered your email
hopefully you have received that
greetings Patrick
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
